96DXCivic
96DXCivic Dork
4/29/10 12:30 a.m.
I am looking for something cheap, carburetored (with the possibility of fuel injection later maybe), small (aka small enough to fit in a Midget engine bay), lightweight and low power (less then 100bhp). I thought about a Toyota 2TC or 3TC. Any suggestions?
Keith
4/29/10 12:33 a.m.
I suppose a 1275 wouldn't fit the bill
96DXCivic
96DXCivic Dork
4/29/10 12:38 a.m.
I have a 1500 but no 1275. I was looking for something with a bit of a power boost over the stock engines.
VanillaSky
VanillaSky Reader
4/29/10 12:44 a.m.
I say a big fat electric conversion would be sweet.
96DXCivic
96DXCivic Dork
4/29/10 12:52 a.m.
I am trying to keep it simple (Read: I don't like electrons!)
thatsnowinnebago
thatsnowinnebago GRM+ Memberand Dork
4/29/10 1:03 a.m.
12a? 13b?
EvanB
EvanB GRM+ Memberand HalfDork
4/29/10 1:18 a.m.
Bike engine?
Keith
4/29/10 1:20 a.m.
I dunno, seems to me an electric conversion would be about as complex as wiring up a starter motor. How hard can it be?
Since all I know about are Miata-related products, what about a GLC engine? They were carbureted, and you can gradually turn one into a Miata engine as you befriend the electrons and go crazy with the multiple camshafts. They've been put in Midgets before so we know they fit.
SillyImportRacer
SillyImportRacer Reader
4/29/10 2:23 a.m.
thatsnowinnebago wrote: 12a? 13b?
That was my 1st thought.
Luke
Luke SuperDork
4/29/10 2:31 a.m.
4AGE? You can run them on carbs easily enough, and they've been put in Spridgets before.
petegossett
petegossett GRM+ Memberand SuperDork
4/29/10 4:37 a.m.
Nice canoe.
To the OP - you need to talk to Nocones about his 12a Midget for input & ideas.
RossD
RossD Dork
4/29/10 7:29 a.m.
X-flow?
John Brown
John Brown SuperDork
4/29/10 7:35 a.m.
Suzuki Swift DOHC with Tracker transmission.
Teh E36 M3
Teh E36 M3 Reader
4/29/10 8:13 a.m.
Damn, John beat me to it.
I honestly think that any carbureted engine past '74 is going to be more complicated that an injected. I'd go for a 4age, or better yet, WAY better yet, G13b out of a Suzuki swift GTi. 1300cc, all aluminum, bolt to a samurai trans, and weigh very little. There are dual weber 40 kits if you are stuck on carbs, but they are also pretty easy to MS. Also there is a website showing how to do it: http://www.ado13.com/dohczuke/dohc.htm
Good luck, and I'd be glad to lend my experience- I swapped a toyota 4age 20v into my midget.
tuna55
tuna55 HalfDork
4/29/10 8:39 a.m.
John Brown wrote: Suzuki Swift DOHC with Tracker transmission.
I like this idea...
If you want carbed, we had a pretty good time with the B18 or B20 from Volvo - right at 100 HP depending on trim and relatively compact.
egoman
egoman New Reader
4/29/10 8:49 a.m.
Supercharged boss 429 with a six speed . See miata isnt allways the answer.
93celicaGT2
93celicaGT2 SuperDork
4/29/10 9:12 a.m.
3tc with a gigantic turbo.
Like this.
http://www.youtube.com/watch?v=GECW2311Cys
Do it.
ReverendDexter
ReverendDexter Dork
4/29/10 9:24 a.m.
egoman wrote: Supercharged boss 429 with a six speed . See miata isnt allways the answer.
I like the way you think.
More seriously, I don't know how light the Toyota T motors are, and at least with the 3T are probably more power than you're looking for.
What you could look at though is a 4A-C. Drifters literally throw those motors away, so they're definitely cheap, my mildly modified one put down 65hp to the tires through a T50 and 6.38" Toyota axle. Only real downside I can think of is that they're not crossflow, but everything's on the passenger side, so in a tiny car, that might help offset the weight balance from the driver just a hair. Also makes turbos way easy, or at least so sayeth the crazy Australians who turbo EVERYTHING.
amg_rx7
amg_rx7 Reader
4/29/10 9:51 a.m.
+2
RossD
RossD Dork
4/29/10 9:56 a.m.
The kent crossflow is seriously small. It was a OEM Lotus seven engine, its gotta be small, and getting 100 hp is relatively simple thanks to Formula ford people. Finding a T50 for a 4age is probably harder than finding a ford transmission to bolt up to a xflow.
ArthurDent
ArthurDent New Reader
4/29/10 10:00 a.m.
Suzuki G10 turbo from a Swift/Sprint/Firefly with a Samurai 5spd. The engine weigh almost nothing and are tiny.
engine delivered 73 hp (54 kW) at 4500 rpm and 115 lb·ft (156 N·m) at 3500 rpm
http://en.wikipedia.org/wiki/Suzuki_G_engine
914Driver SuperDork
4/29/10 10:02 a.m.
There's one locally that was in the CM magazine last year, got a DOHC straight six Jag engine. I may be a liitle nose heavy but it's damn pretty.
Ojala
Ojala GRM+ Memberand New Reader
4/29/10 10:19 a.m.
I would second the Suzuki G recomendation as well as the Subaru EF out of the Justy. Or even worse, I mean better, would be a aircooled VW motor!
96DXCivic
96DXCivic Dork
4/29/10 10:36 a.m.
What kinda wiring would I be looking at doing to convert a Midget to fuel injection? Aren't rotaries a bit porky? I was looking for something not much heavier then the stock engine. What makes carbed engines past '74 complicated? Emissions?
4/29/10 10:38 a.m.
how about an alfa engine.. beautiful aluminum and not too big
there is always the engine out the Miata.. carbs are just a matter of ripping off the injection.. or stay with injection and add megasquirt
zk7eEcDRxqX2A1yMDmEsJKDMkU1wl5J6R2A8lOg1o8pdMVCpbrfmMH0yl74QVcGR
