I'm looking for a junkyard set of steelies. 15" x 7" with a 4 x 114.3 bolt pattern (the same as a 4 x 4 1/2")
Prefer a large offset, like 35- 40 mm
I find plenty of 5 ligs, but no 4 lugs.
Help!
I don't know if they were 7 inches wide, but the '87 Acura legend I junked had a set of 15" 4 x 114.3 wheels. Apparently it's a "Sterling" basically. I've kept them in case they'll fit something, but I doubt anythink I'd get would use them (except my rear drive Corolla's and spacers...to much $).
Clem
Gearhead_42 wrote: S13 240SX I have a set of 4 alloys... come get 'em.
are you positive they are 15x7 and not 15x6? was searching car-part because of your post and everything came up 15x6... i need 15x7 4x4.5 as well.
According to my manual, the only 15x7 4x4.5 factory wheels to come out in the last 30 years or so, was an option on a '00-'06 Sentra.
16vCorey wrote: According to my manual, the only 15x7 4x4.5 factory wheels to come out in the last 30 years or so, was an option on a '00-'06 Sentra.
What was the "standard"?
bluej wrote:Gearhead_42 wrote: S13 240SX I have a set of 4 alloys... come get 'em.are you positive they are 15x7 and not 15x6? was searching car-part because of your post and everything came up 15x6... i need 15x7 4x4.5 as well.
IIRC the standard wheels were 6, the SE wheels were 6.5 ... if not they were all 6.5 Close, but not 7.
I think maybe your manual is in error:
If I am reading all the gobbledygook on the rim correctly, these are 15x7 with a 40 offset...
OK, maybe not... but anyway, that's the wheels I got, that's what the tape measure says across the outer rim surfaces, and the "40" is cast in just inside one of the teardrops...
yeah the offset is +40....
Rim width is measured from bead flange to bead flange, not from the outside.
