Well, I was getting ready to put a head gasket on my vvt engine and found this copper thing in the spark plug hole, I'm assuming this is some kind of crappy thread repair? A spark plug was threaded into it, it goes in and out smoothly. Used but low miles engine. Very annoying
In reply to Streetwiseguy :
There was a spark plug threaded into it with a battered tip. Spark plug smoothly threads in and out of said copper thing
Then that's some sort of repair insert. Looks like it's no quite right, though.
Is there a decent machine shop near you? A proper insert would be the correct depth of thread, and give a proper seat to tighten to.
Anyone have a clue on safe removal so I can see what's been done? A shame, the bottom end looks great and spins smooth. VVT heads are fairly cheap, I'm not sure how much it is to get it repaired at a machine shop. I'm not aware of one locally...
In reply to jfryjfry (Forum Supporter) :
I'm not seeing threads either if that's what you're getting at.
Even in real life I can't see the threads from this angle, but I've triple checked: it threads in smoothly and threads out smoothly. Looking at that cylinder it doesn't look like anything dramatic happened to the valves or piston. I doubt it was running as well with the lack of depth, etc.
