10/28/21 10:56 a.m.
Sponsored Content Presented by Sunoco.
Lead is no longer found in street fuels, but it’s still a popular ingredient in race gas. Time to explain.
frenchyd
frenchyd UltimaDork
10/28/21 11:34 a.m.
They do make a really good point about the difficulty of rating oxygenated fuels.
     I'm found several sources that E85 has 100 octane and almost as many that claim 110 octane.
 if we toss a little lead into E85 does that affect only the gas portion or the whole gallon?
Paul_VR6 (Forum Supporter)
Paul_VR6 (Forum Supporter) SuperDork
10/28/21 12:40 p.m.
It actually makes the knock resistance worse, having tried some blends of E98 and various race fuels to make "E85" legal fuels.
Teh E36 M3
Teh E36 M3 UltraDork
10/28/21 12:49 p.m.
It's interesting to not address the health effects of lead in fuel- I'm sure that it was removed for that purpose as well? That is a question, to be clear.
On a personal level, I have a riding friend who insists on fueling his bikes with 100LL from the local airport. It is so obnoxious (and noxious) to ride behind him. It was also shockingly stanky at the vintage races I attended a couple weeks ago. I dunno, count me out of the leaded fuel camp.
codrus (Forum Supporter)
10/28/21 12:50 p.m.
IIRC the 110 rating is for pure ethanol.  E85 is a blend with gasoline and the allowable blend ratio can be anywhere from 50% ethanol up to 85%.  Obviously the percentage is going to affect the rating substantially, as is the rating of the gasoline it's mixed with.
10/28/21 12:55 p.m.
AIUI, no, the direct health effects of aerosol lead were not really a factor in the legislation.  Those effects are recognized now (there has been some interesting research correlating violent crime rates with the usage of TEL ~ 20 years before, when the people committing those violent crimes were babies), but at the time it was being driven by the goal of reducing smog and thus needing fuel that didn't destroy catalytic converters.
The general aviation industry really needs to get with the 70s and certify engines that can run on unleaded fuels.
Teh E36 M3
10/28/21 1:19 p.m.
Wow- I really didn't know that it was driven from a smog perspective and not general health.  Also- I'm a pilot (but a commercial pilot) who is just dipping his toe into GA, god yes do they need to get with the times. I'm shocked that the GA industry (such as it is) hasn't embraced water cooled engines, like large displacement aluminum LS motors, for replacement and new construction. Crazy. Also, more importantly, stop with the 100ll.
frenchyd
frenchyd UltimaDork
10/28/21 3:05 p.m.
Unless you buy E85 in cans or drums from racing fuel supplies.  There it's always 85% ethanol  without the absorbed water pump fuel has and the gas isn't whatever  but can be  real racing gasoline.  You pay about $1 a gallon more  but the quality is worth it plus it's about what you'd pay for pump grade 87 octane.
10/28/21 3:08 p.m.
Why Did Leaded Fuels Go Away?
To meet the emissions standards introduced in the 1970s, car manufacturers began installing catalytic converters. Lead oxide, a byproduct of combustion, leaves a residue on catalytic converters, rendering them useless. Lead as a fuel additive quickly fell from favor.
Leaves a residue on catalytic converters...oh, and also poisons every square millimeter of our biosphere, that was kind of an issue:
https://www.mentalfloss.com/article/94569/clair-patterson-scientist-who-determined-age-earth-and-then-saved-it
frenchyd
frenchyd UltimaDork
10/28/21 3:29 p.m.
The volume of engines used in general aviation is too tiny to certify  new engines.   Plus there are some die hards who insist reliability comes from old magneto's  not modern electronics.
Who's going to pay for the fight required to get the entrenched out?
  Modern composition airframes and wings water cooled engines. Etc the sky's could get as crowded as the highways are.
dr_strangeland
dr_strangeland GRM+ Memberand Reader
10/28/21 10:17 p.m.
Xylene is 117 octane, toluene is 114 octane.
You can get a gallon of xylene at home depot for $22. Add that to four gallons of 92 pump gas and you should be around 97-98 octane. Without lead.
akylekoz
akylekoz SuperDork
10/29/21 5:30 a.m.
WhAAAAt's lead, but a second hand ElemEnt...WhOOOOh.
Mr_Asa
Mr_Asa PowerDork
10/29/21 5:30 a.m.
And then your seals start to deteriorate.  Those two and plastic or rubber really don't get along.
10/29/21 7:23 a.m.
General health was noted as an aftereffect, decades after lead was removed from fuel.
It'd be interesting to see if there are any statistically significant side effects noted in a decade or two with the removal of sulfur from Diesel.  Probably not, because sulfur isn't as nasty a chemical to animal life as lead is, but still.  Interesting to see...
10/29/21 7:26 a.m.
Much more than $1/gallon. 5 gallon pails of E85 seem to run about $9-12/gallon.
alfadriver
alfadriver MegaDork
10/29/21 8:21 a.m.
If there are, they will more likely be noted along major waterways.   Where the use of bunker fuel within 100miles of the US coast has been banned for a few years now.  Bunker fuel is really bad, and REALLY high in sulfur.  The problem in actually noting that is all of the rest of the emissions improvements of using decent fuel and protections will mute the sulfur  benefits.
10/29/21 11:00 a.m.
Because magnetos ARE reliable.  The entire electrical system can die, and your ancient air cooled engine will continue to run.  A pilot values reliability over all else, because reliable gets you home.
Apexcarver
Apexcarver UltimaDork
10/30/21 8:50 a.m.
What about older engines and valve seats? Would be good to have some more information on that.
10/30/21 9:54 a.m.
There are additives you can put in unleaded fuel to solve the wear problem for engines old enough not to have valve seats that are hard enough.
frenchyd
frenchyd UltimaDork
10/30/21 4:10 p.m.
Guess what!  I've had magneto failures on both engines of a Grumman S2E.
 Doing the mag drop before  take off there was a slight difference  but within NATOPS guild-lines.
 Took Off from Navy North Island ( San Diego ) to Denver  just before I crossed the last mountain range.  First one magneto began to violently misfire. Then the other, I think the pass was about 9000 ft and we only cleared it by using ground effect.  In fact the propeller tips had green grass stains on them when we plopped down on the tip of the runway. And the engines died completely.
   Please do not tell me magneto's are fail proof.
Turboeric
Turboeric GRM+ Memberand Reader
10/31/21 10:00 a.m.
I'm surprised that no-one has pointed out that the molecular structure in the opening illustration is Tetramethyl lead. To get Tetraethyl lead, each of those methyl groups (CH3) has to be ethyl groups CH2CH3. End of chemical pedantry...
10/31/21 12:33 p.m.
Isn't that why the lines connecting the C to the Pb have a kink in them?  To symbolize another carbon with implicit hydrogens on the unused bonds?
But yes, the diagram is mixing conventions of implicit vs explicit Cs and Hs.
10/31/21 1:09 p.m.
In reply to frenchyd :
That's why our engines have two. laugh
Turboeric
10/31/21 2:18 p.m.
I never really liked "kinky" nomenclature - explicit is clearer.
Gearheadotaku (Forum Supporter)
Gearheadotaku (Forum Supporter) GRM+ Memberand UltimaDork
10/31/21 5:51 p.m.
With unleaded gas and HEI ignition, spark plugs suddenly lasted 30,000 miles.
mzzY5iVHfJImMC7AlxPzdQOSVfVhMj18aHj3NK17IeNRNgz5Ocl8iiwfbkaJWsPL
