Mr_Clutch42
Mr_Clutch42 SuperDork
7/30/15 11:37 p.m.
Instead of purchasing an overpriced used Civic subframe, I cut the bracket and welded a square piece to the rest of the bracket. I cut the integrated nut off and just put it in place and accidentally had it big enough to wedge it against the bracket so it can be tightened without holding it.
m_walker26
m_walker26 New Reader
7/31/15 4:37 p.m.
First thing that broke when I bought my wife a 1968 Triumph Tr-250 25 or more years ago was the ignition switch. Went over to the local auto parts store and Robert (one of the owners) says "no way to get one of those fast, but it looks just like a Ford 8N tractor switch. $5 part. I take one home. Fit perfect, works perfect. Sold the car this year with the switch still in place and working.
dean1484
dean1484 MegaDork
7/31/15 4:46 p.m.
I will just leave this here:
Best mod ever to my 924s
MJLJr
97 contour EDIS, coil and mounting bracket's
1994 Mustang V6 plug wires
72 tooth steel gear from McMaster car
7/31/15 6:24 p.m.
323 GTX struts are NLA. So I got a set of take-off Protege5 struts, did a bit of drilling and welding (yes, I welded on the shock body) and put them in the GTX. Worked beautifully, just the right damping.
Best bang for the buck was this morning. I made a brand new 2016 Miata 1.4 seconds faster around our track using two HF tape measures, two pieces of aluminum plate with slots in them, a cellphone with a free angle finder app and a handful of wrenches. Used all that to set the front camber and toe in the pits.
Cone_Junkie
Cone_Junkie SuperDork
7/31/15 6:39 p.m.
The MR2 electro-hydraulic p/s system is my favorite. Used to have a variable resistor to control boost until I fried it with moisture.
I also have quite a few homemade chassis braces made from scrap steel and heim joints, converted a used MINI radiator fan to ditch my mechanical, and have done the McMaster Carr poly-urethane solid mounts too.
Homemade vented hood and splitter-
ebonyandivory
ebonyandivory UltraDork
7/31/15 7:23 p.m.
Mine was making diamond-plate aluminum half-doors for my Samurai by tracing my regular doors onto the aluminum then turning a circular saw blade so it runs backward to cut 'em out.
I spaced them out with blocks of cutting board that I traced out to match the stock hinges.
io7l4Jyan5HRthovpLA11OzTKoyEyrrrZARZtm5XYpbqME3Rzw5dhh4owC5y262U
