miatame
miatame Reader
12/15/10 10:24 a.m.
DEATHTRAP wrote: The AWD versions are only AWD when the computer determines the AWD is needed. Plain english- it is 2WD almost always.
No offense but I'd be interested in fact checking this. I'm pretty sure they have a torque sensing center differential that splits power front/rear. I think it is variable from 30% to 70% front rear...but always sending some torque to the front.
Please post some information to the contrary if you have it.
Oh and you seem to have a lot of experience with the TBSS. Have you seen many/any with missing or broken exhaust manifold bolts? WilberM3 has several missing or broken on his with under 90k miles. Seems surprising to me.
Strizzo
Strizzo SuperDork
12/15/10 10:43 a.m.
not sure how the trailblazer SS handles it, but in the suburban/tahoe, i think it shifts the transfer case into 4hi, and engages the hubs when it senses slip. makes lots of nasty clunking sounds, but gets the job done.
the traverse/torrent/outlook/etc. is FWD until the fronts slip. last christmas at my parents we had 4 vehicles, all on summer tires with 6" of fresh snow everywhere on christmas eve, and the only awd/4wd was the grandparents traverse that we used to go pick up pizza when the restaurant cancelled our reservation and closed. it would allow full-on 4 wheel drifting with the traction control off, great fun and good traction with the all season tires
DEATHTRAP
DEATHTRAP New Reader
12/16/10 11:08 a.m.
The computer moniter the wheel slippage and applied the transfer case accordingly. Broken exhaust manifolt bolts are no that uncommon on any LS motor. But all of the ones that i have seen have always been the ones hardest to get to.
I must correct myself on the transfer case issues. The discription states than the transfer case is always applying power to the front and rear wheels.( I was wrong. ) The computer monitors the wheel slippage and adjusts the ratio accordingly. The normal ratio is 33/67 but can be adjusted as much as 45/55 to as little as 25/75.
hHXJ9bf8uQggP36EUVVF9dxeILL2cKMC08EbYVYETsrj1uTTJN98JuaQGzHVFD42
