So, figured I would do an end of the season follow up on this one. When we last left our intredpid hero, he had ordered a set of backordered Hankook RS-4s from Tire Rack. He waited and waited, and the first autocross came and they still hadn't shown up, so he ran near-corded 225-width Rivals that had sat outside for an entire NY winter. And they were skeeeetchy. A week later, call Tire Rack, still no word on when I'll get the Hankooks. Screw that. Cancelled them and was just getting ready to pull the trigger on the Maxxis and I get a message on Facebook from a guy I don't know saying he heard I was looking for 225/45 Nexens and his shop has them. Weird, but okay. Order them, they are $20 less a tire than Tire Rack and for only $15 he overnight-shipped them from California. Cool!
One thing to note about the Nexens, they run wide for their size. On the left is the old 225-width Rivals on a 15x9. The Nexens are on the right. The BFGs had a definite stretch to them, the Nexen's sidewall is straight up and down.
I also installed the big Racing Beat front sway bar with AWR reinforced mounts. And then I promptly drove the E36 M3 out of them. On the road, they seemed fairly quiet, certainly not like my RE71Rs were. And they were pretty competent in the rain and colder conditions. Turn-in was pretty crisp, plenty of grip and I could slide the back end around a little and not have it instantly come around on me like it would with the Rivals. I put about 8000 miles on them, as well as 8 mini track days at the local 1.1 mile road course, a weird kind of track day at the Lime Rock Park Autocross pad that mostly turned into an oversteer session and 8 autocrosses. What finally killed them was my own laziness. I flipped them once on the rims and should have done it sooner, and I never checked my alignment partway through the season, so I didn't realize that the one rear eccentric had slipped to 4.0 degrees of camber and chewed the tire down to the carcass.
In the end, I would rate them terrific bang for the buck and a pretty confidence-inspiring tire. With them on the car, I felt like I had a much better handle on the car, and got into top 10 on raw times more than once, as well as roughing up much pricier cars around Pineview. But, as I went faster with the car, it became apparent I needed more grip, both in a wider tire and grippier compound, as I was pushing the front end pretty good at Pineview and was having to brake significantly into the corners. And so I ordered next season's tires
Those are 245/40R15 Rival S 1.5s under a stock Miata body. I put them on for a test fit, and I'm going to run them down to a 2-day NEPA event and scrub them in there, then put the old Nexens on for winter storage and put these in my cellar for the winter.
