nhmercracer
nhmercracer New Reader
6/6/14 10:17 a.m.
The left rear window regulator in the 202 gave up earlier this week. I have a new one on the way.
What do you use to lube the regulator? This is a cable and pulley system. As the original failed due to the cable rusting, I would like something which will not evaporate, but not attract too much dirt.
I know, just use some gp grease, right?
Any secrets?
I have also disassembled the right side to lube it also.
6/6/14 10:19 a.m.
Maybe dry moly lube?
But from my experience, when they need lubrication they're not far from needing replacement.
Woody
Woody GRM+ Memberand MegaDork
6/6/14 10:46 a.m.
I have heard that Honda makes some good stuff for this.
Dr. Hess
Dr. Hess MegaDork
6/6/14 10:48 a.m.
White lithium grease is the traditional one.
Giant Purple Snorklewacker
6/6/14 10:50 a.m.
I have used white lithium grease in a spray can.
ssswitch
ssswitch Reader
6/6/14 10:58 a.m.
In reply to Woody:
I know about Shin-Etsu grease but I didn't think it was actually for the window regulator tracks itself (just for where the window glass itself meets the frame).
Is there another Honda grease for that purpose?
Cone_Junkie
Cone_Junkie SuperDork
6/6/14 11:25 a.m.
White lithium is the usual go-to. Wurth true glide (if you could find it) or Motul Tech Grease 300 would be on the higher end of good grease.
AgNUWr0Cjft9cqmlSjd403goh46xTzJM46Ge3LsIfXpDSrPKH2ey5pQsr2j9rxWk
