I want to say that the x1/9 clutch was an upgrade of some sort... but prob would need an exxie flywheel as well... sure someone will chime in
Clutchnet? When I had my milano I knew a vendor who sold the kevlar ones as an upgrade and people had good luck with them. I think they make them for pretty much any car in thr worlds.
Buy a Valeo clutch for a Fiat (X1/9, 128, Strada). The Yugo materials were garbage. Fiat clutches are extremely long lasting and can handle about 10 lbs of boost before they slip.
Yugo clutch and flywheel up to abut 100hp. If you are not going to drive it on the street. You can get a racing clutch without a spring hub. For about $150.
To use the 1500 flywheel and pressure plate in the Yugo. Put the Yugo's ring gear on the 1500's flywheel
I don't know what the power limit of 1500 clutch and flywheel are,stock. First hand. But I think it is ~150hp. If you plan on making more than that you can get a racing clutch with or without a spring hub for about $150.
http://www.clutchnet.com/clutches/browse/10271-clutch-discs?sef=hc
