dxman92
dxman92 Reader
12/30/18 9:57 a.m.
I am running a 9 speed Shimano road derailleur w/9 speed 11-34 cassette and 10 speed Gevenalle shifters. I am looking to potentially upgrade to 10 speed cassette. I've read to get capacity to run larger cassette that I would need a Shimano 9 speed mtb derailleur. Is it possible to run a 10 speed cassette (same 11-34 but 10 speed and gaining extra gear) on current 9 speed road derailleur without swapping parts?
echoechoecho
echoechoecho Reader
1/3/19 12:41 a.m.
depends on which shimano derailleur  you have but if your already running 10 speed shifters on a 9 speed cassette and its working fine then yes you can run a 10 speed cassette with your derailleur. I work at a bike shop and Im always mixing parts (for my own builds) and 9 times out of 10 it works even if the internet says it doesn't.
ultraclyde
ultraclyde PowerDork
1/3/19 5:48 a.m.
Are the Gevenalle shifters set up as friction shift or indexed?
You can make almost anything work 'well enough.' I ran Campagnolo shifters and deraileurs for years with Shimano cassettes using a cable adapter. It worked perfectly in 9 of 10 gears but one was always balky. You could tune it to choose if it was the high gear or the low one, so I made it the hard one and shifted the front earlier.
dxman92
dxman92 Reader
1/3/19 3:21 p.m.
It is a Tiagra medium cage derailleur. Its the stock one that came w/the bike..
Also, I run the shifters in index mode. I've run them in friction a couple times but prefer the feel in index mode.
Alfaromeoguy
Alfaromeoguy Reader
1/8/19 9:25 p.m.
Rubble bikes  England, campagnolo  full Veloce out about 350 400 $. Order Monday recive  on friday. Campagnolo wears in shimano wears out
Sanchinguy
Sanchinguy Reader
1/9/19 7:44 p.m.
What are you using for a crank? Number of chainrings and range of those rings affects the rear derailleur’s ability to shift the entire cassette due to changes in chain tension...
Oh yeah, I’m a bike mechanic at a local independent bike shop...
dxman92
dxman92 Reader
1/10/19 10:54 a.m.
Stock compact 50/34 double that the bike came with is what I'm using.
dxman92
dxman92 Reader
1/20/19 8:52 a.m.
I have found a new rear derailleur for a good price that will handle 36 teeth. Is it worth swapping a derailleur to get two more teeth?
wvumtnbkr
wvumtnbkr GRM+ Memberand UberDork
1/20/19 9:13 a.m.
In my opinion...  no way!
Also a "past" mechanic at an independent bike shop.
Recon1342
Recon1342 Reader
2/21/19 1:08 p.m.
Meh. Just go to 1x and be done with it.
I picked up a Warbird with 1x11 , and I’ll never go back to a front derailleur ever.
dxman92
dxman92 Reader
2/21/19 8:17 p.m.
My next bike will be a 1x. What cassette are you running on the Warbird?
Recon1342
Recon1342 Reader
4/5/19 9:45 a.m.
In reply to dxman92 :
I have a 42t chainring up front, and my cassette is 11-42. My other bike is a 30x18 .
MfnXrnruQBRmxnT0ZRCa63j08JcidVXxI8VRQDqciO3gKOnsTwaVauDJpohSUp7D
