02Pilot
02Pilot Dork
4/25/18 9:20 p.m.
Specifically this one.
I've got a couple projects on the docket for which such a thing might be useful, but I'd rather not buy something that will become an inert lump of Chinese steel in a matter of minutes.
Datsun310Guy
Datsun310Guy UltimaDork
4/25/18 10:18 p.m.
I own that one. I loaned to our weld shop abused it for me.   It’s okay.
I was spoiled by way better drill presses in the 1970’s.
Stefan
4/25/18 10:24 p.m.
Yep.  It works ok, a bit fiddly to get square and mine has a terrible bend at the end of its stroke.
So check it for square throughout the stroke and understand that once you get a bit, etc. in there that you’ll run out of room with the table pretty quickly, there have been a few times I needed a little more height.
Still, compared to the floor mounted one, it fit the majority of my needs without taking up a bunch of space.
I mounted mine to a rotating board that sits on top of a rolling cabinet.  This bird also holds a small belt/disc sander, a polishing wheel, and a bench grinder/wire wheel.  If I need one do the tools, I just rotate the board around to get to what I need.
Grtechguy
Grtechguy MegaDork
4/26/18 6:13 a.m.
I'd say find an old Delta/Rockwell off CL.
1988RedT2
1988RedT2 UltimaDork
4/26/18 7:14 a.m.
I've got a cheap Chinese one with a Ryobi decal stuck to it.  Probably about the same.  It's worked for years, and it's okay, but I feel that there should be a little less slop in the spindle bearings.
Jumper K Balls
Jumper K Balls PowerDork
4/26/18 9:41 a.m.
I don't know if the quality has gone up or down in the time since that drill press used to be green but I have had two. Bought one new and decided it wasn't worth the bench space and gave it away and then somehow ended up with a second one which suffered the same fate.
Lots of runout and a wonky quill that moved back about 3/16" during the last inch of travel and then jammed. Typical cheap chuck that fresh out of the box didn't mesh with they key right.
I wouldn't be surprised if the grey paint version is improved. HF is stepping up their game these days.
RevRico
RevRico GRM+ Memberand UltraDork
4/26/18 9:55 a.m.
Does yours make lots of rattling noises when you shut it off? Mine does, but they could be different models, I only bought mine in 2016.
02Pilot
02Pilot Dork
4/26/18 9:55 a.m.
I'll have to check it out in person, but it doesn't sound like an automatic fail. Thanks folks.
pjbgravely
pjbgravely HalfDork
4/26/18 10:11 a.m.
Mine stalls when breaking though  the hole. It is terrible but drills a lot better than when I use a hand held drill.
hO7DD4zUM9RaT6EgRX1tZnq2qvaWEHT9LwrHZrb2ePJWhJ9NhFVGwHFzds73mIkx
