ditchdigger
ditchdigger Dork
2/13/12 11:14 a.m.
I have an old Clausing-Atlas 4900 series 10" lathe. I saved it from a scrap metal run for $50 about 5 years ago.
Looks just like this
Due to the fact that I have it wired for 110V it has very little torque so I don't use it very much and instead I save all my projects for the 15" lathe at work. That seems silly since I have this sucker in my garage.
I am in process of converting it to a 3hp DC motor with variable speed control so I don't have to mess with belt changes any more. While cleaning it up and checking it out I notice that the cross slide lead screw has almost 1 full turn of slop to it. I need to fix that right away.
Anyway. Is it usually the lead screw or the captive acme nut that wears first? I am trying to save a few bucks and buying both will be over $200. The nut is about $75 from Clausing.
Can I use standard fastener store acme thread and nuts and machine them to fit? Will they be accurate enough?
I have used mills and lathes daily for well over a decade but this is my first dalliance into repairing them.
Giant Purple Snorklewacker
2/13/12 11:31 a.m.
I have a grizzly that I disassembled to clean and adjust. It seems reasonable that you could adapt a screw part from any lathe to any other if they are significantly cheaper - but the carriage nut and half nut parts would need to be replaced and I was surprised that on mine - they were somewhat more complicated a shape than just a captive nut with a nylox screw in them. I would not be able to fabricate one to a different thread spec with my machine skills.
RealMiniDriver
RealMiniDriver SuperDork
2/13/12 11:58 a.m.
I've never played with a lathe, but I work with centerless grinders. If a lead screw is anything like a ball screw, I might be able to help you out. What length, diameter, etc. is your lead screw? Picture?
ditchdigger
ditchdigger Dork
2/13/12 12:01 p.m.
I will pull it apart tonight and measure it. I know it is acme but that is about all I remember.
Hal
Hal Dork
2/13/12 2:44 p.m.
I would save the money and buy the factory parts. You might be able to cobble something together that would drive the cross slide but if the thread pitch is not an exact match your thread cutting ability would be "screwed" (pun intended).
ditchdigger
ditchdigger Dork
2/13/12 8:16 p.m.
Surprise, surprise! I was wrong. It isn't acme thread. Looks to be 1/2-11? and left hand thread. Not standard stuff.
Photobucket
Photobucket
This looks to be the culprit Photobucket
If there was a tap available out there I would be able to make this with no problem. I will look into this a bit more.
In other GREAT news. Look what I scored today.
Photobucket one fuly functional 2 axis DRO. This lathe is gonna be a badass lil' mofo when done.
2/13/12 8:29 p.m.
That is super easy to make if you already own a tap in that size. Otherwise - I suppose you could make it, drill it and go to a shop with a six pack and ask someone to thread it for you.
ditchdigger
ditchdigger Dork
2/13/12 10:34 p.m.
After spending more time with the calipers it is indeed 1/2-10 LH acme thread. Just very worn. I don't have the tooling to cut acme. Calling clausing in the morning.
Taiden
Taiden SuperDork
2/13/12 10:42 p.m.
turn one on your lathe?
novaderrik
novaderrik SuperDork
2/14/12 3:08 a.m.
we've got 1/2-10 LH ACME taps here at work.. too bad you're way out on the left coast..
ditchdigger
ditchdigger Dork
2/14/12 10:06 a.m.
The kind of statement you never want to hear.
"Thank you. We will contact the engineering department and get a quote on how much it will cost to make you one"
I suppose it was overly optimistic to assume they had parts for a 40+ year old lathe on the shelf.
Working on an alternate plan.
Taiden
Taiden SuperDork
2/14/12 10:12 a.m.
Mcmaster Carr
alfadriver
alfadriver SuperDork
2/14/12 10:16 a.m.
In reply to ditchdigger:
If novaderrik has the tap, wouldn't it make sense that someone near you would as well?
And if so, wouldn't it be possible to weld in a sleve, and then tap it? While it takes some work to weld cast iron, it's very possible, and machining isn't that hard for the pros.
Seems as if you should be able to have that part restored locally....
(and I'm enjoying this thread!)
DILYSI Dave
DILYSI Dave SuperDork
2/14/12 10:20 a.m.
I grew up on that exact same lathe. It also had a ton of slop in the screws. It would still make very accurate parts. I wouldn't bother replacing it.
DILYSI Dave
2/14/12 10:33 a.m.
If that's not an acceptable answer, McMaster P/N's 1343K234 and 99030A405 should get you started on fabbing replacement stuff for not too much money.
ditchdigger
ditchdigger Dork
2/15/12 7:17 p.m.
Oddly enough those two part numbers were already whisking their way to me by the time you posted them.
What came this morning Photobucket
Oh yeah.....This is totally gonna work!
So that bronze bit was way too big.
Photobucket
Turned it to 5/8" then bored out the worn threads to that size
Photobucket
Press fit and then a bit of solder to ensure they won't decide to seperate
Photobucket
On to the screw. I cut a piece an inch longer than what I needed to replace and duplicated the old one
Photobucket
Look at how worn the threads are!
cut the shaft off and bored it 3/8"
Photobucket
Then using the dead center and chuck in the lathe to ensure they were as straight as possible I soldered them together.
All reassembled!
Photobucket
I slapped it back together and hot diggity! If there is any slop I cannot measure it. From 0.0987 to as near as I can tell 0.0001 for under $50. I am quite happy.
motomoron
motomoron Dork
2/15/12 11:10 p.m.
That's the exact, perfect repair.
Part of the joy of owning old iron is making the stuff to keep it running. Which of course enables the purchase of more machines so you can make everything to keep all the machines running.
(Says the guy who just finished unloading a 600 pound, 12 drawer Vidmar cabinet alone w/ an engine hoist and pallet jack, cause there's 2 pallets of tooling and cutters that needs to go somewhere)
DILYSI Dave
2/15/12 11:46 p.m.
Nice!
Derick Freese
Derick Freese Dork
2/16/12 1:29 a.m.
This is one of the coolest things I've seen in a while, and I fix stuff with similar methods all the time.
4cylndrfury
4cylndrfury SuperDork
2/16/12 1:52 a.m.
Thats an awesome post, thanks for sharing it! Theres a pretty decent machining section of a metal casting forum I visit HERE... if you visit, youll need to use the drop downs at the bottom to expand the date range of threads to display (stupid issue from switching forum software is this odd limited date range thing). Theres several good machine restos in there, and not just lathes either
diy cnc router
rebuilding a rotary table
alfadriver
2/16/12 6:55 a.m.
That is VERY cool. Nice job!
Taiden
Taiden SuperDork
2/16/12 7:45 a.m.
Sweet!
ditchdigger
ditchdigger Dork
2/16/12 9:09 a.m.
I am very pleased. So much so that I might just try and move the 1000 pound thing out, give it a good cleaning and try and install the DRO this weekend.
Taiden
Taiden SuperDork
2/16/12 11:57 a.m.
Let me ask you this,
how many times did you sit there moving the carriage handwheel back and forth feeling the lack of play with a huge grin on your face?
ditchdigger
ditchdigger Dork
2/16/12 12:08 p.m.
oh not much. 40-50 times is all
XqJVQ8Ucss7kx6H1VsvjEsVhnEoWxfDxjt5fDiNY2IM2igqLzc4aVpHKc4UBV6zw
