douglasroz
douglasroz New Reader
9/16/21 1:27 p.m.
The Benjamin is a quality air rifle that can be used for a variety of activities. It is lightweight and easy to maneuver, making it perfect for hunting and target practice. The Benjamin is available in .22 caliber, which is one of the most preferred calibers among hunters. This rifle has an ambidextrous synthetic stock with a raised cheek piece, rubber butt pad and an adjustable length-of-pull. The gun also comes with a 3-9x32mm scope with rings and an extra set of fiber optic sights.
TECHNICAL FEATURES:
• Velocity: Up to 1000 fps with lead pellets
• Accuracy: 1" groups at 40 yards with lead pellets
• Action: Break barrel cocking system
• Safety: Manual trigger block safety system
• Length: 46" (collapsed); 48" (extended)
• Weight: 7.5 lbs. (gun only)
• Barrel: Rifled steel barrel; blued finish; muzzle break included; removable choke tube (F/M)
• Stock: Ambidextrous synthetic stock with raised cheek piece; rubber butt pad; adjustable length-of-pull; sling swivel studs installed
• Scope: 3-9x32mm scope
rob_lewis
rob_lewis GRM+ Memberand UltraDork
9/16/21 1:38 p.m.
Did you replace the throw out bearing when you did the clutch?  If not, that could be it.
-Rob
Sonic
Sonic UltraDork
9/16/21 3:11 p.m.
Or the input shaft bearing.  I've had one of those wear out in a D series before.
Streetwiseguy MegaDork
9/16/21 4:34 p.m.
Thats bearings inside the trans.  If the noise stops when you put your foot to the floor, both the release bearing and pilot bearing are spinning.  Foot off clutch, no spin.
Listen carefully, and you will probably hear the noise coast to a stop when you depress the pedal.  Thats inside the box.
AKIoIa1fOEshgYtYFaVwJsyaQLk63R2fVIzNmEUUM7Zi4whZHKA8evjUvr8lV4Yc
