DoctorBlade
DoctorBlade Dork
12/11/11 12:41 p.m.
Coming to a shop near you? With rumored Ecotec boosted down the line I suppose. A turbo four would be fun for a lot of projects....
Edit: 12.0 compression? Would that mean 93 octane or worse only?
Brett_Murphy
Brett_Murphy GRM+ Memberand Dork
12/11/11 1:34 p.m.
not if it is a direct injection engine.
Edit: is there any difference at all between the Skyactiv and the Ford engine?
alfadriver
alfadriver SuperDork
12/11/11 3:37 p.m.
Brett_Murphy wrote: not if it is a direct injection engine. Edit: is there any difference at all between the Skyactiv and the Ford engine?
Having looked them both up, they are not the same engine- same basic technolgy- direct injection, vct, high compression, etc- they have totally differerent bore/stroke- assuming the web pages are correct.
Ineresting crate motor. Not exactly tuner friendly, nor it's a particularly attractive engine.... hmm.
12/11/11 6:56 p.m.
not pretty.. but could be good for a 7 clone
corytate
corytate HalfDork
12/11/11 8:03 p.m.
the numbers arent even that good imo. the korean 2.0 direct injected engine makes 200/200 ish. with lower compression.
They could have uncomplicated the whole thing by making the same power with less compression and mpi instead.
Ranger50
Ranger50 Dork
12/11/11 8:14 p.m.
If i have read I could from friends that attended PRI, that motor is for a spec racing series more then anything. Then the EcoBoost version is for real crate motor swaps.
alfadriver
12/11/11 8:17 p.m.
Ranger50 wrote: If i have read I could from friends that attended PRI, that motor is for a spec racing series more then anything. Then the EcoBoost version is for real crate motor swaps.
So it's related to the new Formula Ford I recently saw? I thought it was going to be the non DI engine, but it would make sense that it's the spec motor for FF... Interesting.
fast_eddie_72
fast_eddie_72 SuperDork
12/11/11 9:41 p.m.
Nice! 160 - 175 HP and all aluminum! I want one!!!111!!1!1!!
12/12/11 6:36 a.m.
I would assume 160 to 175hp, all aluminum.. and clean. You can probably get more HP out of it.. but the emissions out of this engine will suffer
7Hsdi6vbHFKx8CGFk4cPJocMiht07S3tNQrWzRPoUuLalxnVzgCX1ktP2K85ueXz
