rustybugkiller
rustybugkiller HalfDork
3/30/19 9:20 a.m.
I know the center bore needs enlarged but after that is done Im wondering if they will clear the brakes. 2001 civic ex. I really don’t want to enlarge the center if they won’t fit anyways.
John Welsh
John Welsh Mod Squad
3/30/19 10:15 a.m.
There are 2 styles of Miata daisies.
90-93 are 14x5.5 these are easiest distinguish by the fact that they are made with a cap to cover the lugs.
94+ are 14x6 these are designed to have exposed lug nuts.
No guarantee that either will fit the Honda but even less likely the small ones will.
Example: the smaller ones will not fit on a Mk1 MR2 but the larger will.
Images here
rustybugkiller
3/30/19 10:42 a.m.
I have 2 sets of the early daisy (with center cap) and they both have good sets of all season tires going to waste. Maybe I’ll pick up some steelies for the Honda then. Thanks!
Nugi
Nugi Reader
3/30/19 1:37 p.m.
Iirc, miata center bores are too small for hondas, no matter the generation.  If you want to rely on lug-centric centering and diy em, or have them machined for honda center bore. Second concern is backspacing, I think the miatas run less EDIT: After looking at the linked chart, you might be ok for offset. 4x100 for all but nc iirc, so if they clear your brakes and hubs youre ok. Most honda brakes will fit 14's, as nearly all base models came with em. Edit2: your exs are bigger, and will fit some aftermarket 14s, but maybe not stockers...
KNZXUrwoSj0b11sdwC08UzN23LzE6irwaYLs5qVLIiV0la3fEf3UeVUT6Zpn3rqW
