Woody (Forum Supportum)
8/3/22 5:35 p.m.
Total watch building rookie here.
Short version of the much longer backstory:
Back in 1989, I saw this ad, or one just like it, and decided that I wanted an LL Bean Deluxe Field Watch.
It was a quartz watch, made by Hamilton, and had the LL Bean logo on the face (not necessarily something I would choose today, but I liked it a lot back when I was a kid). Bought it, loved it for a couple of years, but then sold it to help finance the purchase of an old motorcycle that I decided I wanted more. I never really regretted selling the watch, and went many, many years without ever wearing another watch.
A few years ago, I decided that I kind of missed that particular watch and decided to replace it. It had long since been discontinued by LL Bean, and there wasn't really a comparable watch available from Hamilton anymore. (This was pretty low end for a diver's style watch).
So after some searching on eBay, one finally turned up ("Just needs a new battery!"), so I bought it, dropped in a new battery and... nothing. I filed a complaint, got my money back, and the seller told me to keep the watch. I tossed it in a drawer for a couple of years, but never forgot about it.
I have a new Hamilton watch now. It's much nicer, much bigger and much heavier. I like it a lot, but I actually miss the feel of the lighter, cheaper old watch sometimes.
I wrote to Hamilton, as well as a couple of watch repair specialists and no one wants to work on a quartz watch.
Last night, I found this guy's blog. He actually collects LL Bean branded Hamilton watches, and said that an ETA 2804-2 mechanical movement will fit inside the case.
In another post, he also talks about just dropping in a replacement quartz movement, assuming I can figure out what's in there, and then find a new replacement.
I've never done this before, but since this watch is otherwise useless, I'd like to give it a shot.
I'm okay with the idea of keeping this one Quartz, but would consider either Quartz or mechanical options.
First, I need some tools. I have a cheap watch repair kit ($18 on Amazon), but I bought that for removing links for the bracelet of the other watch, and even all the metal parts seem to be made of single-use Chinesium.
I've opened the case of the old watch by hand, but I'd really like to get the proper tool to do that job, along with anything else that I will need. I don't need top of the line stuff, but I don't want crap tools either.
Once the tools arrive, I will need your collective wisdom, because I have no idea what the hell I'm doing.
Thank you.
8/3/22 5:51 p.m.
"Hamilton 9399"
8/3/22 7:28 p.m.
Caliber is ETA 963.116
8/27/22 10:47 a.m.
Who makes the best tool for opening and closing the back of a watch case like this?
Javelin
8/27/22 11:18 a.m.
In reply to Woody (Forum Supportum) :
I have the cheap tool and it works fine. I'll dig it out when the cat gets off of me.
j_tso
j_tso HalfDork
8/27/22 11:30 a.m.
I like this 3 pin tool, Harbor Freight sells one too. The 2 pin tools slip easily and can scratch the case.
There are also rubber balls that use friction on the back to twist it, even less risk of scratches with that.
I also use this wood holder so it doesn't slip in my hand.
8/27/22 11:35 a.m.
In reply to j_tso :
In my mind, it just seems like the two pin tool would be easier to hold securly against the case, but I've never used either, so I'm just guessing here.
j_tso
j_tso HalfDork
8/27/22 11:49 a.m.
I hold it like I'm using the 2-pin tool, so it's more points of contact. I wouldn't use the handle for leverage unless the watch is clamped in a holder and the holder is securely mounted to the table. I scratched up the back of my Seiko SKX the first time using the 2-pin tool in the HF kit.
dxman92
dxman92 Dork
8/27/22 1:07 p.m.
I think Victorinox makes a tool to open up watches with. I'll have to see if I can find a link to one.
Javelin
8/27/22 1:55 p.m.
This is what I have
The tool is the big thing on the left
8/27/22 10:29 p.m.
I decided that I was probably going to need a few more specialized tools, so I ordered a tool kit that includes the three prong tool from Jules Borel. It looks like the same kit as sold by Esslinger and Teddy Baldassare.
http://www.julesborel.com/s.nl/it.A/id.32113/.f?sc=31&category=991205
Items included in this kit:
  • Case opener knife for snap backs
  • Jaxa screw back case opener
  • Scratch brush for cleaning
  • Silicone grease for case gaskets
  • Plastic battery tweezer
  • Buff stick for pressign in batteries
  • Band holder verticle for sizing bands
  • Hammer 1 oz.
  • Band pin punch set 0.80mm and 1.00mm
  • Pin pusher for band spring bars
  • Flat nose plier 4-1/2” to pull pins
  • Loupe 3X
  • Three screwdrivers: 1.00mm, 1.40mm, & 2.00mm
  • Cleaning cloth 12” x 12”
  • Spring bar tool
  • 100 assorted spring bars
  • Brass tweezer #3
  • Stainless tweezer #3
  • Stainless tweezer #5
  • Pin vise four jaw
  • Hand installing tool
  • Hand remover
8/28/22 7:28 a.m.
I wasn't able to track down a new ETA 2804-2 mechanical movement (and I don't know enough about this stuff to figure out what else I can effectively stuff into this case), so I decided to hit the Easy-ish Button and ordered an NOS replacement ETA 963.116 Quartz movement off eBay. It's coming from Switzerland and won't be here until the middle of September, so I should have some time to get on YouTube to watch and learn (!), and maybe I'll have some idea of what the heck I'm doing before I actually try to do it.
Floating Doc (Forum Supporter) GRM+ Memberand PowerDork
8/28/22 8:21 a.m.
This is a really cool thread. Now I need to ignore any thoughts of copying it.
6AmReg0vMWZiYUxOQpIpo6gJSoRxpYRo2Mi70UECYwzlA8NKnIFmyFiOLKgoMuc8
