I've got two holes/tears in a brand new tarp, each approx 4 inch IIRC (was going to take a pic but it's dark so early). Wind was ripping it across the edges of my solar panels and I didn't realize.
What ideas do you have to fix them? TIA.
I've used denim iron on jeans patches to fix boat covers. I would hand sew around the patch edges and the tear with dental floss after ironing.
The challenge is keeping the rip(a weak spot now) from getting bigger. A couple of grommets and rope could make a shoelace like arrangement wouild help.
If it's the blue plastic ones, I wonder f a bicycle tire repair kit would do it. Cut up a tube for the long tears.
Buy a small sized poly tarp of the same type and cut it up for a patch and evidently use JB Weld Polyethylene glue.
Resin-Expert.com: Polyethylene and Polypropylene Glue – How to Bond Thermoplastics
They are 12' x 10' I believe. I thought maybe there was a cheap patch kit or something but maybe it's not worth it. Maybe I can just throw some duct tape on both sides of the hole? Or flex seal tape? Has anyone used that?
I could look how much a smaller tarp is and use the jb weld idea, but I may as well just buy another full size tarp in that case... I'm leaning toward tape at this point as it sounds like there isn't a tarp patch kit that anyone knows of.
I like the idea of a bicycle tire repair kit, thx.
For a tarp that size it's probably going to be cheaper to just buy another one. If you still want to try fixing it, back in the day a lot of guys used this method for patching tears in dirt bike motorcycle seats: cover the hole with duct tape, and then heat up the tape with a heat gun or a propane torch. You have to be careful if you use a torch so you don't melt the tarp. This will 'weld' the tape to the tarp, and it will probably hold up for quite a while as long as the tarp isn't whipping in the wind.
stuart in mn said:For a tarp that size it's probably going to be cheaper to just buy another one. If you still want to try fixing it, back in the day a lot of guys used this method for patching tears in dirt bike motorcycle seats: cover the hole with duct tape, and then heat up the tape with a heat gun or a propane torch. You have to be careful if you use a torch so you don't melt the tarp. This will 'weld' the tape to the tarp, and it will probably hold up for quite a while as long as the tarp isn't whipping in the wind.
Gorilla tape is the one to go with using this method. I haven't fixed a tarp with it but I have patched some wheel well liners and with the heat applied and stuck in it has held up well for a month now, we will see what winter brings. I believe ¯\_(ツ)_/¯ does this on the underside of his rally cars and that was where I first read about it.
stuart in mn said:cover the hole with duct tape, and then heat up the tape with a heat gun or a propane torch........
Do you only put the Duct Tape on one side ?
When I am patching a car cover hole I try and put the tape on both sides , so near the center of the hole it has a chance for the duct tape glue touching the other layer glue at some point ,
I never tried the heat gun but will next time.......thanks for the idea
Thanks for the tip about heating up gorilla or duct tape, that sounds like a good idea.
@lotuseven7, thx I had no idea they were that cheap.
I still want to fix it though, so I don't have a useless tarp. And I think the hot tape trick might be what I try. I do both sides if I do it.
They make permanent Gorilla tape and by accident, I found out the hard way.
Menards.com: Gorilla® 1.88" x 25 yd Black All-Weather Permanent Duct Tape
