I was out earlier and came across this Supra sitting with a for sale sign in a bar parking lot in Vermillion, OH (20 minutes from my house.) It looked good enough that I circled back to have a look. It is very clean. Sign says '86 Original Owner. It is an automatic trans, non turbo with gray cloth but odo says 93k miles!
I did not call about it myself but took pictures if someone wants to know more. When I got home, I opened CL but I could not find the car listed there.
However, when on CL looking for this Supra, I came across this '90 Cressida in Wakeman, OH (which happens to be 30 minutes from my house.)
https://cleveland.craigslist.org/cto/d/1990-toyota-cressida-with/6636440068.html
The highlights:
The full ad reads:
For sale as is. 1990 Toyota cressida with Supra turbo motor swap. Was stored for about 7 years inside and out. Not currently drivable but getting close. The body is relatively rust free and solid. It's a limited edition so has power leather seats sun roof power windows door locks alarm system and real fake wood trim. Was a automatic car. Now 5 spd. car is rear wheel drive. 16 inch alloy wheels. Some one jacked the radio and some of the dash around radio is cracked. Interior is worn but still usable. Now to the good stuff. 7mgte turbo motor intercooler with r154 5spd trans. its a JDM spec engine with Stock Toyota t26 big turbo. usa model was rated at 230hp and 250ftibs torque. this is jdm spec so may have a little more hp but these things are very tunable to 600 hp. Replaced clutch master and slave cylinder with oem Asian parts. Replaced water pump thermostat and belts. A.c. compressor is locked up so no a.c. for now. replaced brake master cylinder with brand new unit, front brakes working but needs a rear caliper and rotors, has new toyota pads front and rear. Brakes need work and tires severely dry rotted and cracked barely hold air. Has a good battery and starts and runs with no check engine lights. Has stainless down pipe 3 inch to muffler. Previous owner did Conversion was done very well with all oem parts. It's a bring a trailer car since the brakes don't work fully and the tires will pop on the first bump. Has 126000 miles clean car fax. Ohio title in hand. Would make a great track car solo drag, drift car or lemons. Or fix up and have nice sleeper driver. almost all the electrical suff works power window power door locks sunroof all lights work except reverse lights. power seats mirrors with alarm system all working well.auto meter boost guage in a pillar pod. selectable cooling fan for turbo. has adjustable fan control with dual electric fans and big all brass radiator. cleaned flowed and resealed fuel injectors and new intake gaskets. so to recap to drive it needs rear caliper rear rotors and tires. questions email or text. no trades please no dreamers dont waste my time if you cant afford to buy it. must sell $2500 obo reasonable offers only please. need the driveway space. Thanks
The Cressida could be a "buy-it" not "build-it" Challenge car. Sure you have to negotiate the price down a lot but...
It needs tires and tires are budget exempt for challenge purposes.
As for rear brake caliper/rotor, Rock Auto has $25 rebuilt caliper (or rebuild yourself) and $11.26 for rear rotors. Fresh pads are budget exempt. So, even with shipping of caliper and rotors the total price is about $50 from RockAuto.
If the Cressida is as stated (big if) then if you could buy it for $1,900 it is Challenge capable. Maybe down to $1,600 would leave room for newer wheels.
