What tools do you take with you? I have to install seat belts, so obviously I will need for that. Since it's a '78 Chevy, I'm figuring a full range of SAE wrenches, flat and phillips screw drivers, sleeve of sockets, spark plug socket and ratchet. Anyone have issues with tools getting stolen?
I'd like to bring the electric impact, but I'd rather carry it on. Any issues there with that? You know, it is "gun" shaped and with the condition of "help" the TSA employs I'd hate to have that confiscated for whatever reason they deem.
I'm not equipped with any personal experience in the matter, but I did find this handy chart:
https://www.seatguru.com/articles/tsa_prohibited_items.php
It appears that wrenches, pliers, and screwdrivers under 7" in length are okay in carry-on, but power drills are not. My guess is that the TSA would classify an electric impact as a power drill because gubmintforthechildrenterroristsnineeleven.
I've flown with tools several times for work, but it's only been hand tools. I usually put them in my suitcase and check the bag. Never had an issue that way. The couple times that I carried them on, I was always stopped at the X-ray machine for a closer look.
Unfortunately I've not taken any power tools, so no advice there.
Some helpful answers there. Zip ties and extra hose clamps were great. Don't forget the small 1/4" and similar sizes in case you have to take apart interior trim like I did. A cigarette lighter adapter with 3 outlets and USB is great, along with a GPS. Smart phone is also a life saver.
I've never brought tools. I want to do a fly and drive, not a fly fix drive and pray I make it home.
That being said, my FNDs are always cheap. I've done 6 FNDs, my last was a $900 car.
The closest I've come to a fly-n-drive was going out to Michigan to buy my '79 Spitfire from fujioko/Doc Brown. That was more of a "drive-n-drive" as a friend went with me and drove my minivan the 600+ miles home. Tools? Not sure I took any, although I have a tool kit for my GT6, so I might have put that in the van. Either way, I have a AAA card. Granted, I was going on the assumption Jim wouldn't sell me a turd (and he didn't).
Credit card, cell phone, aaa card. Did buy jumper cables during one trip where I had an overheating alternator. A lot of cars have tool kits.
DrBoost wrote: I've never brought tools. I want to do a fly and drive, not a fly fix drive and pray I make it home. That being said, my FNDs are always cheap. I've done 6 FNDs, my last was a $900 car.
I wish I could say it was that cheap, but alas, its not. I know it's a solid example and runs and drives, but it is 40 years old, so I'm trying to prepare for the worst and hope for the best.
I also thought I should bring my small jump pack. I'm checking the tools underneath so no worries about long screwdrivers at the TSA checkpoint.
What is most likely to go wrong that you will legitimately be able to do a road side fix on?
Look up how-to's online for the specific vehicle and then bring the tools you'll need for that.
A checked in bag of tools can add up in weight very quickly. If you're going to get charged for an overweight bag then it may just be cheaper to hit up harbor freight in AZ. Buy the budget SAE socket set and bring this month's coupon for a free screwdriver set.
I just did a 1000 mile fly n drive sans tools.
I was planning to hit harbor freight to buy a cheap kit, but flight delay put me in after they closed.
I would also focus on roadside fixes. Things you could actually do. You're not changing a rear axle on the side of the highway, or a timing chain.
Stuff you can do:
With that in mind, it really focuses the list of tools you might need.
I will also add that I have checked a 50lb suitcase of tools before and it worked fine.
The last FnD I helped orchestrate didn't require any tools, although I can tell you that an R129 500SL with an aftermarket exhaust sounds great echoing off the buildings in Vancouver. In terms of an impact wrench, if it's corded and you have the sockets to show that it isn't a drill, it should fall under small appliances like alarm clocks, although I'm not too sure regarding south of the border.
No need to pack zip-ties, duct tape and other small items. As a previous poster said--- head to a HF, or AutoZone when you land, and purchase the cheap stuff you may need.
I'd also buy a roll or two of this:
This tape bonds to itself, so it's perfect for fixing hoses, or CV boots that have torn. I always have a roll in my glovebox. I'd also bring a crappy old blanket, steel wire, and a cheap flashlight. Old car / truck exhausts like to fail at very inopportune moments, and laying on the wet/ cold ground isn't much fun.
Bobzilla wrote: What tools do you take with you? I have to install seat belts, so obviously I will need for that. Since it's a '78 Chevy, I'm figuring a full range of SAE wrenches, flat and phillips screw drivers, sleeve of sockets, spark plug socket and ratchet. Anyone have issues with tools getting stolen? I'd like to bring the electric impact, but I'd rather carry it on. Any issues there with that? You know, it is "gun" shaped and with the condition of "help" the TSA employs I'd hate to have that confiscated for whatever reason they deem.
Whilst planning an aborted trip two weeks ago I had come to the notion that I would ship my gear to a UPS or FedEx store nearest the location and retrieve it with an Uber from the airport to avoid the bag check, TSA problem, and lugging bulky stuff around with me like a helmet and boots. It was going to be around $80-100 shipping for me to walk on the plane empty handed except for a wallet and a book.
Last night I packed up a bag of goodies. wrenches, ratchet, few common sockets, screw drivers and a hammer. Also had a box of fuses from the C4, so those went in as well. small jump pack, 2 flashlghts and the seat belt/ harnesses and bolts. All told, 46lbs with the hard sided suitcase I'm putting them in.
Joe Gearin wrote: No need to pack zip-ties, duct tape and other small items. As a previous poster said--- head to a HF, or AutoZone when you land, and purchase the cheap stuff you may need. I'd also buy a roll or two of this: DEI Quick Fix tape This tape bonds to itself, so it's perfect for fixing hoses, or CV boots that have torn. I always have a roll in my glovebox. I'd also bring a crappy old blanket, steel wire, and a cheap flashlight. Old car / truck exhausts like to fail at very inopportune moments, and laying on the wet/ cold ground isn't much fun.
I got a sample of that tape, or at least a very similar product, through work a while back and thought to myself "This is going to be one of those things I clean out of my glove box in 5 years and wonder why I ever put it in there." But I put it in the glove box anyways because I'm a pack rat.
Well, lo and behold, it ended up saving the day a few months back when my Jeep started pissing coolant all over downtown Harrisburg one day. Didn't totally stop the pin hole leak in the upper radiator hose, but it did slow it down enough to get me home. So, I'll second this suggestion.
Stupid suggestion - head to a nationwide chain store near your pickup (walmart, etc) and buy one of the 99pcs tool kit. Use or don't use it, return it when you get home.
No need to worry about the throwers or TSA monkeys liking your Snap On tools, or leaving them on the side of the road, or having them stolen, etc etc. Since fuses are small, light, and ungodly expensive, a few of those would be nice to have but not really necessary, can always pull fuses for radio, power windows, etc. Modern cars have a lot of duplicate fuses.
Only thing I would do is pick up some consumables like engine and trans fluid, check before you leave, monitor on the way, since you dont know the history.
It's an old truck, if it can't be fixed with a hammer, pair of channel locks, pair of vise grips, screwdriver set, and a cheap SAE wrench set it's probably not a repair one can feasibly perform in a parking lot. Check the tire pressures, all the fluid levels, and make sure the front wheel bearings aren't getting hot.
I vote to get some cheap, essential tools somewhere after you arrive. Skip the hassle of dealing with the TSA and hoping your stuff makes it through. Even if you check a bag, it could get lost along the way, and that would suck. Find a HF, auto parts store, or a 24hr Wally World nearby and get what you need.
Even better: if you know someone that lives near the vehicle, send them to get what you need in advance!
Funny how many of us who live really close to a H-F quickly suggest that. When I lived in Portsmouth, NH the closest H-F was about an hour away in MA.
For my 3k+ mile fly-n-drive, I just went to a wal-mart and spent $60 on a socket set, screwdriver with interchangeable bits, wrench set and pliers. I ended up using some of it to swap parts and save some cargo space, but I didn't end up needing any of it - that said it was cheap insurance.
Bah. 4 way, 2 spare tires, phone, duct tape, zipties, done. You have 2 days, inspect rubber items and replace before leaving as necessary.
