QuasiMofo (John Brown)
QuasiMofo (John Brown) MegaDork
7/30/23 1:13 p.m.
So I will need an adapter plate to mate a SBC/LS engine to a Subaru 4EAT transmission. I am not going to spend $2000 for the one that is made by Subarugears, although I believe that it's worth the money. This will be as close to a zero budget build as I can get. I have access to not only the bulk material from a dumpster but I am going to be learning CNC mill programming at work and things like this would be excellent "scrap fodder".
I need a resource for the ridiculous stuff like this. Like "Here's the bellhousing for a SBC in XXXX design program" and "Here is the bell housing for a Subaru 4EAT", then I combine the two while locating crank centerline and bam Sv8aru adapter plate exists.
I think that we have mentioned trying to collect the drawings before, has anyone found a real viable solution?
Mr_Asa
Mr_Asa UltimaDork
7/30/23 1:45 p.m.
Do you have access to each right now? Maybe a cover plate for either? Might be the easy button. Lay them out on graph paper and just take the measurements.
7/30/23 2:23 p.m.
In reply to Mr_Asa :
No I don't have access to any of the drawings currently, but I am just starting the planning for this.
Manual transfer and measure is my current plan.
Mr_Asa
Mr_Asa UltimaDork
7/30/23 3:22 p.m.
In reply to QuasiMofo (John Brown) :
To be clear, I didn't mean access to the drawings, I meant the patterns via the actual parts.  Not sure if thats what you meant as well, but clarification is always helpful.
For the SBC I would probably ask the H.A.M.B. if no one here turns up anything.  Would bet money someone there had it
7/30/23 3:30 p.m.
I've got SBC at work, can get it for you tomorrow. Have you googled these yet?
californiamilleghia
californiamilleghia UberDork
7/30/23 6:24 p.m.
I know of a guy that made a motor to transmission adapter in layers !
he designed it so it could be laser / water jet cut in layers and then welded / bolted the layers together ,
Just an idea :)
7/30/23 6:34 p.m.
SBC bell housing pattern should be cake to find. As should LS, which is not necessarily the same. I found this in 10 seconds: https://www.gt40s.com/threads/chevy-ls-bellhousing-bolt-pattern.31312/
I have a Subaru to VW adapter, which means I should be able to come up with the Subaru pattern if necessary. Not this week, though.
7/30/23 6:44 p.m.
Subaru:
From here
7/30/23 8:16 p.m.
Hell this was on GRM already surprise Im not saying I hadn't Googled it, because I have both images saved but the ability to combine all of the resources is where I was going with the thread
I appreciate all of the help you all have given.
MrJoshua
MrJoshua UltimaDork
7/30/23 8:59 p.m.
Lol@ Keith-Apparently "not this week" means"Give me 10 minutes". smiley
Stampie
7/30/23 9:56 p.m.
rPawVzUPfm4vdl7endGFZoK5WNUEAFyT0H8uO4gs6Krs0GXqeHiE7szJ9jT1lQkF
