dj06482 wrote: At those speeds, you have to wonder about the tires on both the truck and the trailer. That's a lot of heat!
Video says they swapped the tires on the trailer for something rated for that kind of speed.
I'm surprised it could go that fast with the stock final drive ratio. I don't think mine could make it with the 3.73.
carguy123 wrote: I'm surprised the truck could do that speed, much less pulling a trailer.
A thousand horsepower will push an awful lot of air out of the way. :)
codrus wrote:dj06482 wrote: At those speeds, you have to wonder about the tires on both the truck and the trailer. That's a lot of heat!Video says they swapped the tires on the trailer for something rated for that kind of speed.
And since the truck had DEM RIMZZZ......so probably higher speed rated tires as well.
DaveEstey wrote: I'm surprised it could go that fast with the stock final drive ratio. I don't think mine could make it with the 3.73.
A .61 6th gear with 3.73s, stock 245/75R16 tires and 3250 rev limit works out to 129 mph. The tires in the video didn't look stock though.
I dunno how high you can rev a Duramax LBZ before the rods let go, but a fairly modest rear end swap should give 140+ fairly easily.
codrus wrote:carguy123 wrote: I'm surprised the truck could do that speed, much less pulling a trailer.A thousand horsepower will shove an awful lot of air out of the way. :)
FTFY
