benzbaron
benzbaron Dork
7/11/11 7:59 p.m.
Well after about 7 years of flawless use the water heater decided to crap out. I can get the pilot light going and it will stay lit for about 5 min or so, but if I turn on the burner, the burner fires and both the pilot light and burner go out. If I don't turn the burner on the pilot light will stay lit for about 5 min then flame out. I watched the pilot light burn out and it almost looks like it is getting a draft or something which is either blowing out the pilot or cooling the thermocouple enough that it turns off the gas.
I pulled the burner with pilot light, starter, and thermocouple out. I cleaned the pilot and installed a new thermocouple and the same thing happened again, the pilot starts and will stay on but if I turn on the burned and both the pilot and burner go out.
I actually checked the old thermocouple on the stove and it puts out 25mV so I think it isn't the problem. I am starting to run out of options besides replacing the thing as if the problem is a with the thermostat it basically makes the unit BER (beyond economical repair).
Any tips or suggestions are appreciated, the user manual is pretty useless and keeps referring to a "qualified installer" or some other nonsense. Taking a cold shower is a bit of a sobering experience and I don't need any of those.
Thanks folks and hopefully I get this thing going pretty soon.
Curmudgeon
Curmudgeon SuperDork
7/11/11 8:03 p.m.
Okay, it has a new thermocouple. BTDT. That's definitely the first place to start. It's possible the valve is full of corroded gunk from years of use, that's the next place I'd go.
fasted58
fasted58 HalfDork
7/11/11 8:27 p.m.
Remove n blow out the pilot gas tubing w/ compressed air if possible. If the pilot flame was yellow or orange it needs adjusted by the pilot screw on the main valve till it's burning blue. There should be a pic in the manual for proper flame envelope around the thermocouple.
TucoRamirez
TucoRamirez Reader
7/11/11 8:39 p.m.
Make sure the connector from the thermocouple to the control unit is seated and tight. I think my OE thermocouple nut was reverse thread and the new one was not or some other such wierdness.
aEmvpf7LgDJNkBJHGsuVaA4PkJuJTuwF0NcuZfYHlyrLNLbK1PkeyZgWmqctHo3c
