Got a line on some really cheap stocks. I want to use them for an art project, but want to find out what they might be before it ruin them. They remind me of M1 Garand stocks, but I dunno.
Not sure, but the semi-circular relief on the front left side of the receiver cut and the large relief cut for the top of the buttplate are obvious unique features and should help to narrow it down. The holes in the butt are probably for cleaning supplies, which points to military and something with a door in the buttplate.
Have you considered chemically stripping them to look for cartouches?
All the Google pics of "M1 Garand stock" look an awful lot like what you've got there. Even saw one of a cleaning kit, that fits in holes not unlike the size in the butt, but it wasn't cut out on the top, presumably for a hinge.
M1 Garand stocks are shorter, and don't have the relief on top for the folding buttplate.
Remember, the M14 was a "product-improved" M1. They kept some of the looks, but added lots of in-vogue features. Detachable magazine, flash hider, hinged buttplate, selector switch ...
In reply to NoMini :
Compare to the M14, which looks a hell of lot like an M1 with a detachable magazine and select fire.
TJL said:Mosin nagant 91/30. That thick laquer screams old commie guns. I have a few, they are fun.
Definitely not. 91/30 stocks are straight, not gripped. The cuts are wrong too.
I'm going with the M14/M1A - the top of the buttplate as shown in the other photo is consistent with that deep and complicated relief.
TJL said:Hmm yeah. SKS?
Upper hand guard looks too long to be SKS. Profile is off as well. I’m leaning M14.
Although as you mentioned, the heavy lacquer does scream Soviet.
It has a notch for the bolt of a bolt-action gun on the right side. I'm going to go with M1903 based on that and the 2-pin screws on the sides - "C" version in this photo missing upper furniture
Edit: also, those stocks aren't set up for a detachable mag, so more than likely a clip-fed internal magazine bolt gun.
No, $15/ea is not overpriced. If they had the handguards with them, they would probably be worth closer to a bill each. Of course, if you have no use for them then they are just sitting there sucking up $30.
I just wanted to mace sure if I was to hack on these things, I wasn't ruining something valuable, like a stock from a Johnson rifle, or something.
Pricing depends on the condition and markings. The right cartouche, if it's rare, is worth bucks to collectors. It may allow completing a rifle restoration with the "correct" markings.
Kind of like date-coded hoses on a collector car.
Strizzo said:It has a notch for the bolt of a bolt-action gun on the right side. I'm going to go with M1903 based on that and the 2-pin screws on the sides - "C" version in this photo missing upper furniture
That notch on the right side is for the M14 selector switch (may not be present on an M1A stock). Hail, hail, rock and roll!
And it sure looks like there's space for a detachable magazine.
