fastasleep
fastasleep Reader
2/20/09 4:43 p.m.
Anyone have any write-ups or info on building up a 4.3? Also, what manual trannys would be a good mate for a HO 4.3?
-Les
cwh
cwh Dork
2/20/09 9:22 p.m.
Any trans that fits a SBC will bolt up to a 4.3. That's all I know, good night.
rebelgtp
rebelgtp HalfDork
2/20/09 9:28 p.m.
I personally don't but I know my uncle had built one for his brothers stock car back when there was still a track around here. He has always sworn by them, I think he said the pistons and rods are the same as a 350.
fastEddie
fastEddie Dork
2/21/09 7:26 a.m.
Yes, it is 3/4 of a 350.
Grtechguy
Grtechguy SuperDork
2/21/09 7:51 a.m.
look up GMC Cyclone
Grtechguy
Grtechguy SuperDork
2/21/09 7:52 a.m.
http://en.wikipedia.org/wiki/GMC_Syclone
Grtechguy
Grtechguy SuperDork
2/21/09 7:52 a.m.
rebelgtp
rebelgtp HalfDork
2/21/09 10:55 a.m.
http://www.youtube.com/watch?v=KkglxJH6jGE
Here is one with twin turbos on a dyno pulling 1200 hp
DILYSI Dave
DILYSI Dave SuperDork
2/21/09 11:30 a.m.
Les - FYI, I have 4.3 Vortec (the good one - 200 / 265) that I'm going to be ditching at some point in favor of a SBC. I'm a little hesitant to do so, but I need more V8 in my life. Anyway, depending on your time frame, might have your motor, and locally.
Monkeywrench
Monkeywrench Reader
2/21/09 11:41 a.m.
4.3L engine builds..
http://www.hotrod.com/techarticles/engine/113_0208_chevy_43l_262ci_v6_engine_build/index.html
http://www.speedtalk.com/forum/viewtopic.php?t=13471&postdays=0&postorder=asc&start=0&sid=223104fc4a05f8f85c13732685ddffee
http://www.hotrod.com/pitstop/hrdp_0705_pitstop_chevrolet_v6_performance/index.html
pete240z
pete240z HalfDork
2/21/09 11:47 a.m.
We had a 200hp factory version in our 1994 S10 Blazer and that thing rocked. I still feel it excelerated faster than the 265hp ?? Trailblazer we now own.
Must be the extra 2000 pounds on the Tblazer.
Strizzo
Strizzo Dork
2/21/09 12:25 p.m.
fastasleep wrote: Anyone have any write-ups or info on building up a 4.3? Also, what manual trannys would be a good mate for a HO 4.3? -Les
iirc, the late 90's gmc sonoma and s10 "xTreme" were available with the 200hp 4.3 and three pedals. might be a good start
gamby
gamby SuperDork
2/21/09 12:33 p.m.
cwh wrote: Any trans that fits a SBC will bolt up to a 4.3. That's all I know, good night.
I'll be damned.
fastasleep
fastasleep Reader
2/21/09 7:00 p.m.
DILYSI Dave wrote: Les - FYI, I have 4.3 Vortec (the good one - 200 / 265) that I'm going to be ditching at some point in favor of a SBC. I'm a little hesitant to do so, but I need more V8 in my life. Anyway, depending on your time frame, might have your motor, and locally.
Great! Thanks! I am just kicking a couple things around, but if you could see up my sleeves right now!
Thanks for the input, guys. I will look at the links tonight.
-Les
BTW, what is the compression ratio of the 200 hp version?
carguy123
carguy123 Dork
2/21/09 11:09 p.m.
fastasleep wrote: BTW, what is the compression ratio of the 200 hp version?
Turbo coming?
fastasleep
fastasleep Reader
2/22/09 7:20 a.m.
Turbo coming?
Absolutely, but I have heard that these engines don't handle a lot of power (up to 300-ish) before they come apart. I have thought many times about a 4.3-powered something, but up until now I didn't know what.
-Les
Xceler8x
Xceler8x GRM+ Memberand HalfDork
2/22/09 12:37 p.m.
Doesn't the Brunton Stalker use a 4.3 as well?
MikeSVO
MikeSVO New Reader
2/22/09 1:35 p.m.
I have a friend who put a turbo on on his GMC Jimmy. Really, I put the turbo on it, but still he sorted out the tuning and stuff. He ran low 12's in the quarter with it, and I think 7.70s in the 1/8, and with him in it, that thing must have weighed a LOT. It was an '02, with the Vortec motor. He never even got into the motor - it was stock. Still had that crappy EFI it came with, though he was able to make it work somehow. The tranny had some upgrades, IIRC.
stumpmj
stumpmj Dork
2/23/09 8:40 a.m.
Xceler8x wrote: Doesn't the Brunton Stalker use a 4.3 as well?
Nope. 3.8
internetautomart
internetautomart SuperDork
2/24/09 8:15 p.m.
vortec 4.3 from 96-02 is fine
vortec from 92-95 is finicky and not worthy
virtually anything not related to the # of cylinders from an SBC will work on a 4.3.
http://www.gmperformanceparts.com/Parts/catalog.jsp
SpeedyWilson
SpeedyWilson
6/9/09 12:51 a.m.
Hey, I'm new here. I am building a Locost/Lotus 7 type car and have been thinking about the 4.3 also.Hotrod magazine done a tech article about the 4.3 gm engine a few years back. The bore and stroke is the same as a 350 but dont be fooled. The little end in the rod is offset to account for the no. of cylinders and the firing order in crankshaft degrees. I think gm just wants to make people buy parts but a 350 rod wont work with the stock piston because of the clearence to the bore at top dead center. A 4.3 type v6 was used in the Daytona Dash racing series and the heads used were Brodix. You have to use thier intakes with the heads though and they only come in single plane. 49cc chamber too I think...to high CR.. 4 bolt main caps from a 350 can be installed. Use a non-balance shaft block(88 and Back?) . Late vortec heads can be pocket ported and roller rockers from the 350 used. 87 and back used a hei distributor. The casting no on the head I think is 901 for the good one but don't quote me. Contact the Cylinder Head Exchange. They know. Will try to find a link or to to help out....
SpeedyWilson
SpeedyWilson New Reader
6/9/09 12:59 a.m.
found a link.....hope it helps....
SpeedyWilson
6/9/09 1:11 a.m.
Ok....found the article, bash the new guy for not reading first and posting but I did it in the interests to help....
cwh
cwh Dork
6/9/09 10:36 a.m.
We don't bash new guys, and even tolerate moderately bad spelling. You must be used to those other forums.
wherethefmi
wherethefmi HalfDork
6/9/09 11:42 a.m.
i will bash you, in the face
3Xvd4wcqi1bl0cl1RMZE7zDv5eUraUocf5GtxcCsGVvqsRAjJuZcbnPqXliq0snU
