9/18/20 1:28 p.m.
Fairing on my R-90 broke at one  of the four fastener points.  I see no fiberglass, it's smooth inside and thin, so I assume plastic.
Any other suggestions?
Dan
9/18/20 1:30 p.m.
You can patch ABS nicely by melting other ABS in acetone and using fibreglass mesh (aka "drywall patch tape")  as a structural agent. I use a rasp/file on a chunk of ABS pipe to get shavings and then mix in acetone until I have goo that's about the consistency I want.
mtn (Forum Supporter)
mtn (Forum Supporter) MegaDork
9/18/20 1:31 p.m.
3M 5200 if you're sure you can set it right, and are sure it will never need to be undone...
Mr_Asa
Mr_Asa SuperDork
9/18/20 1:42 p.m.
This is what I do.
nutherjrfan
nutherjrfan UberDork
9/18/20 2:32 p.m.
I did just use jb weld on two tabs for a Vino side cover.
Haven't put it back on the scooter yet but it seems decently strong.
I used the stuff that takes four hours to set then 16 to cure ( app. )
Had to use painters tape to hold it in place initially. Maybe the quicker setting stuff wouldn't need that?
It was the twin plunger set up with the sealing cap.
9/18/20 3:12 p.m.
Thanks, nope, never (I hope) coming apart.
k0xCOETrcp8oWOxEaOYKPkKKGz8VoznjJIeamr7lmxHWjD2Xe0J1yRXc07TlfvnZ
