aircooled
aircooled MegaDork
8/30/22 6:25 p.m.
OK, so this thread will just be a super, just in case backup, found here:
 Archive:  https://web.archive.org/web/20210612231319/https://grassrootsmotorsports.com/forum/simulation-central/assetto-corsa-on-pc/174453/page1/
This is June of 2021, but better then nothing.  I will paste it here for (sort of) safe keeping.  Dean, you said there was some useful server setup info somewhere in the thread, you might want to pull that out also.
If necessary, we can create another thread and use these as the start again.
GRM ASSETTO CORSA RACE NIGHT
Weekly - Wednesday
   6pm Pacific - 7pm Mountain - 8pm Central - 9pm Eastern
Race Server Name: GRM_TEST (The password is the three letter acronym of a popular automotive magazine based in Florida. (lower case)
Join the Discord channel: Unofficial GRM Forum to allow audio chat.
Next Race
Short sprint races to evaluate some cars and a course. Download and install the following (link at end of post)
Track:
Cars:
Download the cars and required track from the link below:
https://drive.google.com/drive/folders/1vME9C0pSEoHrops3ol6xEer_0FAp-C54?usp=sharing
Archive of non-original cars / track we have used:
https://drive.google.com/drive/folders/1UHbJVB_Wvlp1n_-vaZBGW9_WTXlKIc0u?usp=sharing
aircooled
aircooled MegaDork
8/30/22 6:27 p.m.
Setup and Getting Started Info
Discord download (for voice chat and info): https://discord.com/download
Content Manager and Shader patch - Highly recommended (CM requires a donation for full function, but WELL worth it):
 https://acstuff.ru/app/  (yes it's from Russia)
 https://acstuff.ru/patch/  (not required by greatly improved graphic / appearance)
Sol graphic mod (not required but greatly improved weather /sky / atmosphere and some other effects): https://www.racedepartment.com/downloads/sol.24914/
Suggested add-ons:
Helicorsa (adds nice overview of cars around you):  https://www.racedepartment.com/downloads/helicorsa.5199/
FFBClip (adds way to graph and easily adjust force feedback, per car): https://www.racedepartment.com/downloads/ffbclip-app.7910/
Sidekick (a more detailed "info" bar for speed, gear, tire temps etc.): https://www.racedepartment.com/downloads/sidekick.11007/
Getting Started with Discord:
This looks long/complex, but I assure you it goes pretty fast and its very easy to use.
1) Read the Discord thread, if you wish: https://grassrootsmotorsports.com/forum/simulation-central/grm-discord-channel/177517/page1/
2)  Download Discord from https://discord.com/
3)  Once you get it up and running, send me a message on there.  My name is prodarwin#1538.  Put it in the upper left box.    Just let me know you want a GRM invite and your forum name if I don't have any way of identifying you.
4) Make sure your mic works.  I suggest you go to user settings (bottom left of screen):
Click voice and video, adjust your volumes, and your devices if necessary.  You can select push to talk or 'voice activity'.  Discord is actually very good at deciding when you are talking, so it works pretty well and saves you the need to bind a button.
5) Once you are in the forum, if a bunch of stuff has a locked symbol, PM one of the mods.  They will need to add you to the GRM group so you have access to the sub-channels.
6)  When you are in the discord, you'll see this bar on the left, with all the channels you can join.
The important thing to note here is, when it comes time to play AC, look for the Assetto Corsa channel, if it shows some people below it, they are currently in the channel, which probably means we are racing.  Just click to join.
If you are in a text channel and want to get someone's attention you can @ them and it will display a notification, or send a push notification to their phone.
Logitech Wheel setup Info:
  Logitech Profiler Settings (a good starting point at least):
In game Wheel settings (a good starting point at least):
  (The 107% Gain is a bit of a secret best setting to reduce the center dead zone apparently)
Assetto Corsa / Shader Patch suggested settings changes (from base):
Remove windshield glare (Settings - Assetto Corsa - Video):
Set readings to 'murican units:
Content Links:
https://www.racedepartment.com/  primary source (use Google to search)
http://assettomods.com/   nice cars and car packs (seems to be Australian focused)
https://assettoland.wixsite.com/assettoland  well organized cars and tracks.
https://tarnhoerner.de/   car packs for various classic racer series
 https://vrc-modding-team.net/  Formula 1 cars and tracks
Here is a link to my Google drive with some resources that will be a lot easier to get here:
https://drive.google.com/drive/folders/1YNsvldx4s2nMVtNPHlTTUtBHrcy_TgDU?usp=sharing
Currently up there:
 - 7zip installer (use this to decompress car and tracks).  The default Windows decompress seems to work fine though.
 - Logitech Profiler (essential for setting up a Logitech Wheel)
 - Logitech GHub (needed for Logitech G29 wheel)
 - NVIDEA texture exporter plug in for Photoshop (needed to edit car textures)
 - NVIDEA stand alone texture exporter (no need for Photoshop)
Note: the NVIDEA tools are not needed if you have the Content Manager. I could not get the plug in to install in the latest version of PS anyway.
Here is a good link for how to setup a Logitech G27 wheel (G29 should be the same):
https://steamcommunity.com/sharedfiles/filedetails/?id=276305371
G27 (and maybe G29) should work best with gain set to 107%.
Some Tracks that might be of interest:
Bridgehampton:  https://www.racedepartment.com/downloads/bridgehampton-race-circuit.6604/
Trial Mountain (for GT fans):  https://www.racedepartment.com/downloads/trial-mountain.2348/
Riverside: https://www.racedepartment.com/downloads/riverside-international-raceway.9492/
Bathhurst: https://www.racedepartment.com/downloads/bathurst.8677/
Spa (update): https://www.racedepartment.com/downloads/spa-francorchamps-the-real.31068/
Deep Forrest (visuals not done): https://www.racedepartment.com/downloads/deep-forest-raceway.32848/
Mid Ohio (not at RD): https://assettocorsa.club/mods/tracks/mid-ohio.html
VIR: https://www.racedepartment.com/downloads/virginia-international-raceway.11892/
Summit Point: https://www.racedepartment.com/downloads/summit-point-raceway.29502/
NJMSP:  https://www.racedepartment.com/downloads/new-jersey-motorsports-park-lightning.14212/
dean1484
8/30/22 7:59 p.m.
Air that is bloody fantastic!!!!  You found it or most of it anyway. I was going to say I can delete my first couple posts and we can back your post with all the info up to the top.
Then I can cut and past the current series stuff I posted and we are off to the races maybe leave a post or two of yours after the top post of yours for specific current race stuff.
dean1484
8/30/22 8:01 p.m.
Actually if I just delete my top two posts and you cut and past in to your first post and Pro delete his post we are good to go I think.
cmcmillin31
cmcmillin31 GRM+ Memberand New Reader
8/31/22 5:23 p.m.
I've tried several different ways of unzipping the modern GT3 cars on the "OneDrive", and trying to install them one at a time.  Unfortunately, I keep getting corrupted file/content not found error messages by content manager.  Not sure if there's a workaround, but I'm unable to use any of that content.  I've never had a problem using any files posted on the google drive until now, I'm currently at a dead end with those cars.
dean1484
8/31/22 5:38 p.m.
I can give you a link to my one drive and I will pull the individual cars and zip them up separately and put them there. I think there may be an issue with the 911 and the Supra. I eliminated them from the server as I was having issues. We can play with the cars on the other server or I can put up the set of race cars I put together. Or we can just do some one make races tonight and other people can digest cars to use.
RAcxtFcjRKl4uXV3VIBrxnFVjZOezqgoauraEeJ5BnOKOhV3zSx3Qm44sAAbq8I8
