vazbmw
vazbmw Reader
8/31/10 7:31 a.m.
Update to the stand up scooter project: Paint and finishing done:
Disc brakes and highflow custom exhaust added
Custom highflow intake added 200cc goped project
Grtechguy
Grtechguy SuperDork
8/31/10 11:35 a.m.
pretty cool
vazbmw
vazbmw Reader
8/31/10 11:47 p.m.
Thank you. It is faster than I expected it to be.
triumph5
triumph5 Reader
9/1/10 11:39 a.m.
Sny issues with the tires having heat problems from the speeds? Or have you just used it for short runs, where that isn't an issue?
I built a go-cart using wheel-barrow tires when I was a kid, three laps around a very long block, and they were coming seperating from the rim. Granted, they were tubeless, but they had bearings, and bolted on so easy....I used a 3/12 hp engine from a land mower, belt drive, and a "clutch" from the center section of a bicycle wheel bolted to bar stock, that in turn was bolted to the frame. When I pushed the bar-stock lever forward, it tightened the belt, and away I went. It was fun. Until I melted the tires....
zomby woof
zomby woof Dork
9/1/10 11:42 a.m.
That's pretty awesome!
vazbmw
vazbmw Reader
9/1/10 9:01 p.m.
Thanks ya'll
I have only done short runs so far for shakedowns, so tires are not an issue. Plus they are very old tires from recycled bikes. Once I finish it up, I will get better tires and possible disc brakes. I didn't expect it to go 40 mph. It is geared pretty low also so it has good torque. But hay, a 60lbs vehicle with 7 hp 11lbs/ft of torque should move out pretty good.
motomoron
motomoron Reader
9/2/10 9:06 p.m.
Cool. Keep the orthopedist on speed dial.
vazbmw
vazbmw Reader
9/2/10 9:18 p.m.
I am an old man...I won't be doing max speed. been there done that. Too many surgeries, too many broken bones But, here is how it looks with onboard Video:
motomoron wrote: Cool. Keep the orthopedist on speed dial.
Grtechguy
Grtechguy SuperDork
10/17/10 9:14 a.m.
My only suggestion? Mtn bike disc brakes.
vazbmw
vazbmw Reader
11/21/10 8:49 p.m.
I have done the disc brakes and this thing stops great. I need disc on all my motorized bike thangies. Updated images in the first post
Gzr2iLGhYIUI2r46o9Kw3jVYE61WaJbgvMaydf21k0Rlm8Po1zBbR08mqMGYbuiL
