I am trying to figure out what would be the best way to get ABS brakes on a 6 wheeled vehicle.
I'm planning out the conversion of a vehicle from 4 to 6 wheels. The original vehicle already has ABS brakes and want to bring that over to the extra 2 wheels that would be added on the back. For reference,I have experience restoring and working on cars but have never”experimented” with ABS systems.
First off, I haven't found any info on how existing 6 wheeled vehicles like vans and small trucks do this, that is, if they even bother having ABS on the extra wheels??
My first thinking was to add a second ABS pump(the exact same model as originally on the vehicle) to the vehicle. This while leaving the original ABS pump/braking system alone(mostly). For reference, the existing ABS pump is an earlier version that doesn’t have can bus so should be relatively easy to work with when modifying.
My thinking is to connect the rear(L+R) outputs and sensors of the additional ABS pump to the new rear wheels. I would block off the front outputs to the brakes(not connect them to anything). Then connect the front(L+R) sensors either to the existing front ABS sensors or somehow add new sensors to the existing ABS ring on the hubs.
My thinking here is that the additional ABS pump would now have something to reference off for wheel speed difference(the front wheels). Would something like this work? Would not using/blanking off the front outputs work or create a problem? Any suggestions on how to make this work or completely different ideas for the same result are very welcome.
Diagram for reference.
I’m going to move this to the main forum. I think you’ll get more eyeballs there.
Good luck with the project.
A simpler solution might be to change the rear ABS from working on a per-wheel basis to a per-axle basis - so the 2nd axle would get a ring on one side and the output from the matching corner split to both sides, the 3rd axle would get a ring on the other side and the output from the other corner split. The downside is that this would be kind of like old-school 3-channel ABS on both rear axles, but production cars with ABS tend to have a ton of front bias anyway and basically never lock up the rears so I think it could work quite well. If similar weight is now spread across both rear axles that could change and you may need to alter the bias to suit.
I was going to suggest something similar to Gameboy.
Assuming a 4 channel ABS, I'd have one circuit for each of your wheels on one side in the front, and have one channel operate both those wheels.
The traction on those two wheels is going to be close enough that the ABS should do a reasonable job operating those wheels in the same manner.
One thing to be careful with is that some ABS units do "electronic brake differential". That is, instead of having a mechanical proportioning valve in the system to lower the rear pressure, they use the electronics in the ABS. Wild speculation here (I'm a software guy, not a proper engineer) but it seems like that might work OK with a dual-rear-drive-axle thing (like a semi tractor) but perhaps not so well if it's got 3 equally spaced axles down the length (like a 6x6 APC)
so, you're adding a second rear axle?
is this to increase the load carrying capacity of the vehicle, or just to look cool?
what are you planning to do for a master cylinder?
Good suggestions here. But id still be more comfortable getting something set up where each wheel is controlled independently. This would be for a ground up build/restoration so in my eyes isn’t gonna make much difference in the amount of work. Plus I like the challenge.
My question would still remain, would blanking off the front ports and connecting the front sensors on the front wheels be a viable option?
The spacing would be like on the diagram. One axle in the front and two axles closer together in the rear.
The car originally has a separate brake proportioning valve so im assuming there wouldn’t be an integrated system within the abs pump/unit.
The extra wheels would be for extra load capacity in the back but in reality 95% of the time I wouldn’t actually be transporting extra load. So that would then make it for looks.
Im planning on putting a master cylinder and brake booster from the performance version of the original car that will be more than capable of handeling the extra two calipers in the back.
What do tractor trailers do for abs? Anyway to adapt the hardware with a performance software? I guess those don't deal with hydraulic pressure but air pressure thought, right?
