(As seen in my Toyota MR2 Build Thread)
Have a nasty gasket you need to scrape off, but don't want all that crud in your engine? Of course you do–you're on this forum!
Fortunately, there's a quick and easy way to do things, and it won't result in a ruined engine. It's called... SHAVING CREAM!
Buy some super normal shaving cream, then fill every nook and cranny with it. Like so:
Then, scrape whatever needs to be scraped, and let all of the crud fall onto the cream. Once you're done, vacuum every thing out with a shop vac, and the cream (and the crud) will magically be removed.
It's probably a good idea to still do an oil change a few miles after using this trick, but it does eliminate hours and hours of disassembly and cleaning on a job like this.
I heard about this a couple weeks ago from a machinist I was building a wiring harness for. I honestly thought he was full of crap.
Apparently not.
Now to buy some shaving cream. (I'm bearded. So, none in the bathroom)
Dusterbd13 wrote: Now to buy some shaving cream. (I'm bearded. So, none in the bathroom)
This.
That's a good idea, beats futilely trying to us tape and paper and crap to catch the junk.
Someone mentioned it in a stripped spark plug hole thread the other day as well. I don't remember who, but it went something like this.
Set the cylinder at BDC, fill with shaving creme, tap hole, rotate engine to expel shaving creme and shavings.
Now I guess I'll have to get a can of regular shaving cream for the garage. I use gel.
That would just add to the questions I get when people see what I have in the garage. What works very well as a lubricant when working with rubber seals is a lubricant designed for use in a different room in the house, $ex lube. Spray with water and it gets slick again when starting to dry out. Is water soluble and don't damage rubber. Now explain why that is in your toolbox.
