We were scared of the mysteries inside the old ATE master cylinder and its Reagan-era ABS voodoo.
We were scared of the mysteries inside the old ATE master cylinder and its Reagan-era ABS voodoo. We bypassed it, we thought, with some wiring trickery, but we couldn’t be sure if brake pressure was properly proportioned or if the system would even work if it lost electrical power. It had to go.
Some Internet sleuthing told us the Ford Mustang SVO had non-ABS brakes with the same four-wheel-disc system as our Lincoln. We nabbed a used vacuum booster from a junkyard and a new SVO master cylinder from our local parts store.
Next was brake bias. OE manufacturers usually bias their proportioning valves very conservatively, and anyway our car’s weight distribution is much different than when it left the factory. So we called up Speedway Motors and ordered an adjustable proportioning valve instead of using the street piece we pulled from a Mustang.
Want to keep tabs on the latest LeMons lunacy and ChumpCar camaraderie? Subscribe now for tons of additional crapcan content delivered to your home or shop throughout the year. |
Why not just "bench bleed" the master cylinder on the car? Bolt it up, run your return lines, use the mechanical advantage of the car's God-given brake pedal. Throw a few rags underneath when you reconnect the brake lines. Easy-peasy.
What combination of adapters did you use to match the threads of the prop. valve to the threads on the brake line? Would you recommend steel adapters for brake line, or are aluminum, brass etc fine?
Displaying 1-3 of 3 commentsView all comments on the GRM forums
