The GRM crew has been busy with the Lincoln, and most of that time has been spent undoing past sins. Whoever first prepared this car should have their wrenches confiscated and their butt kicked.
The rear suspension was a mess, and we think we have it banged back into shape. After more than one try, we found some OE-grade shock absorbers that fit. Their mounts did require some grinding, however.
While we were back there, we also removed the parking brake. Snip.
The front suspension also required some work, as the upper strut mounts had been unceremoniously hacked apart. We didn’t even have an upper strut mount bushing to work with. The car did come with some homemade camber plates, and they served as our starting point.
Tim had an idea, and most of the base materials came from our local Lowe’s: rod ends, some bolts and tubing. The angle iron came from the scrap bin. The resulting creation locates the top of the strut and should withstand a few curb hops.
We also fabricated a dashboard, as we had nowhere to mount our gauges, switches, etc. The solution was simple: a piece of scrap aluminum riveted to some square stock. The gauges and switches are a mix of swap meet finds and the ones that came with the car.
We also beefed up our cage, tying it to the A- and B-pillars. Now it’s starting to look more like a race car.
We still have a long to-do list:
R&R coolant (It’s gross)
Replace the brake calipers (They’re gross, too)
Source brake lines (One’s missing)
Plumb fuel system
Mount tires
Finish installing the seat
Fix shifter
Install a kill switch
Install window net
Install battery box
Fix waterpump (We think it leaks)
Wire lights
Change fluids
Flush master cylinder
Flush steering rack
Reinstall glass
More wiring
Install side-view mirrors
Flush the clutch master cylinder also (if it's a man. trans.) - the 38 year old fluid in our Lemons car prevented the clutch push rod from returning, and we smoked a clutch!
It's a Lincoln Mark VII... They were never made with a manual unless you do a Mustang tranny swap! ;)
I saw one of these on my local CL this weekend for $2500, after seeing this project car I am sorely tempted to go find that car and take a closer look. I won't be turning it into a racer if I like what I see, but will use some of your ideas for "improving the breed", so to speak.
Unfortunately, the only Mk VIIs I ever run across either look like the project car here, and are just as hacked to bits, or are VERY high mileage examples and the electronics are shot....especially the ones controlling the rear suspension.
Displaying 1-5 of 5 commentsView all comments on the GRM forums
