How to make your own ethanol blend | Fuel Tips
Sunoco
By Sunoco Fuels
Apr 11, 2023 | Sunoco, Fuel Tips, Sponsored Content, Ethanol | Posted in News and Notes | From the May 2022 issue | Never miss an article
Photography Credit: Chris Tropea
Let’s say your car isn’t configured to run on E85, but you’d still like to take advantage of the benefits offered by ethanol–like more power and a cooler-running engine. Can you run a smaller concentration to get some of the perks? Quite possibly.
Welcome to modern times, when most pump fuels contain some ethanol. It’s a renewable resource that also increases a fuel’s octane rating. Most pump gasolines carry the E10 designation, meaning they contain up to 10% ethanol.
E85, as the name suggests, contains even more ethanol. The standard, however, allows the content to range from 51% to 83%. By the way, ethanol content testers start at around $15.
While the extra oxygen found in ethanol allows an engine to make more power, there’s a tradeoff: More ethanol is needed to make that power, hence the need for higher-capacity injectors and fuel pumps. Plus, the fuel system components must be compatible with ethanol.
So, if E85 is too much for your system and E10 isn’t enough for your wishes, can you make your own blend that’s somewhere in the middle? Yes.
In the grand scheme,” notes Zachary J. Santner, senior specialist of quality at Sunoco, “gasolines are blends of hydrocarbons. So you can continue to blend them for your own desired purpose.”
Let’s say, for example, that your fuel system can handle some ethanol but can’t deliver enough to support E85–like, maybe E40 sounds like the right concentration. You can mix in some E85 or E98 and, using a weighted average, compute the final blend. (Sidebar here: While the ethanol content of pump E85 can vary, Santner notes that Sunoco E85R always contains 85% ethanol; likewise, the brand’s E98 recipe never changes.)
Here’s that weighted average formula:
Join Free Join our community to easily find more Sunoco, Fuel Tips, Sponsored Content and Ethanol articles.
Comments
chaparral
chaparral GRM+ Memberand Dork
3/29/22 12:31 p.m.
Most people running ethanol blends have settled on E30; made with 93 AKI fuel it gives about 96 AKI and 102-103 RON.
zUAW33co73gpiWlObBj4pOnooZGZ26zWdxUE0BoHC63pI41hYaLFzYqlNzvhbEy2
