BrokenYugo
BrokenYugo MegaDork
7/1/17 11:38 p.m.
Ransom
7/2/17 12:14 a.m.
Damn.
Damn damn damn.
Damn.
Do I have to go to Seattle tomorrow? I don't have a trailer...
Or any parking.
SVreX
SVreX MegaDork
7/2/17 6:33 a.m.
It's orange.
That means its mine, right??
128racecar
128racecar Reader
7/2/17 1:18 p.m.
Looks far better than the typical rust mobiles we have in the Midwest.
Overheating after a short drive with these is usually bad head gasket rather than thermostat. Compression will often be okay, but don't let that fool you. Not a bad fix, but you need to shave the head the absolute bare minimum.
Stefan
7/2/17 2:50 p.m.
128racecar wrote: Looks far better than the typical rust mobiles we have in the Midwest. Overheating after a short drive with these is usually bad head gasket rather than thermostat. Compression will often be okay, but don't let that fool you. Not a bad fix, but you need to shave the head the absolute bare minimum.
or swap in a Honda drivetrain and move on.
It could simply be that the coolant system is improperly bleed as the X-1/9 is notorious for being difficult to bleed. You basically have to raise one end of the car higher than the other. If you raise the front, there's a bleed nipple on the radiator that is known to fail, but its the proper way to bleed the system.
UMbGiKwRoyTN9JMkxNF9pqZVfts3Dp8qzeJs5Vi5nxb7K7xnyECDtt7lziQG5PE8
