My first guess id the freeze plug behind the flywheel.
It only gets worse guessing from there
Unless there is a coolant hose in your swap at the top of the engine that is leaking. I don't k ow af an sbc with anything like that other than heater hoses in a factory application though.
tuna55 said:Those carbs were known to be troublesome, but I have no firsthand accounts. Beware.
Which ones? I upgraded it last year so if you're speaking to the first one I initially had on the car it has been replaced and has run much better since last year when I switched over.
Dusterbd13-michael said:My first guess id the freeze plug behind the flywheel.
Unfortunately no other potential leak above that area that I could see. The oil definitely wasn't contaminated though as I just drained it and it was clean. Guess I'll start pulling parts off.
BarrettRC8 said:tuna55 said:Those carbs were known to be troublesome, but I have no firsthand accounts. Beware.
Sorry I missed that, it was the BG carb which I was referring to.
It has been a while. Car is running great, which of course means that I'm debating putting in an LS motor. Regardless, took it out a few weekends ago and got some cool pictures I thought I'd share.
It's been a long time since I've updated this because nothing had really changed. In the Spring I picked up a salvage 2001 Porsche 911 Turbo. Pulled the engine, transmission, and brakes a few weeks ago and am planning on putting the 3.6 TT and G96 into the 1972.
Also picked up and Eastwood multiprocess welder. Thought this forum might be a little less judgmental if I have some questions along the journey. 😂
I also pulled the wiring harness and ECU. Spoke with a shop in LA who is interested in working with me regarding a custom harness and standalone ECU.
I still need to remove the ABS control unit and then I'll be ready to get rid of the shell and start disassembly of the 1972. Anything else I should pull off of the Turbo before I get rid of it?
I would pull all electronics from the interior, especially instruments and every switch you can find including everything key related.
In reply to Piguin :
Understood. I'll get to it tomorrow. Even though I'm having a custom harness and standalone ECU installed you think that's required? Better safe than sorry I suppose.
Put the 996T engine and transmission under the car just to get an idea of the work ahead. I didn't have time to lower the car for a clearance check but I'm nearly certain the engine will fit on account of the measurements I took. Interestingly, the 996 motor mounts are only about an inch wider than the '72s.
The torsion bar and likely a bit of the floor will need to be cut though.
Thought - Should I change the title of the thread?
In reply to docwyte :
In the first iteration I'm going to run the engine as is. It was making about 550 to the wheels when I pulled it. The previous owner did some modifications that we didn't get into but he showed me a dyno sheet.
Who knows after that. But even getting the car running properly will be a few year endeavor given everything else I've got going on.
