EP 1: Starting the rust bucket
All we need if fuel and spark, simple right? Not really.
After sending 12v to the in tank pump and the 2nd pump, only the first pump made noise, which is supposedly enough to get the engine running.
The E30's fuel lines were rotted out almost completely, so we ran temporary rubber lines, one from the pump to the fuel rail and the other from the return to a empty container to catch returning fuel.
Now turning over the car actually pumped fuel to the engine but still no start. Next we replaced the plugs, distributor cap and rotor with new parts.
Old Cap:
New Cap:
Now the car would turn over, but only run super rough on a what sounded like 1 or 2 cylinders.
Maybe faulty wires? Checking each plug for spark while cranking the car disproved this, showing spark on every plug.
After some more research we decided to check the crank reference and position sensors:
Doing a quick resistance test, both sensors readings where within those specified in the Bentley service manual. Then we checked the wiring from the sensors to the ecu connector with a multimeter, it was fine.
The last thing we could think of was an ECU issue, so we took that out, opened it up and found no water ingress or anything noteworthy. At this point we were stumped because we had fuel and spark but the car would not run.
Checked the compression on each cylinder, as well as fuel pressure at the rail, everything was in spec.
Finally we decided to try swapping out the old ignition coil with a newer one we had lying around, and to our surprise, the car fired up and ran perfectly. What was happening is that the old coil was working, but just barely, outputting enough power to create a spark but not a strong one, thus not igniting the fuel in every cylinder.
Now the e30 runs!
What the setup looks like:
Obviously this solution is temporary just to see if the car could run, next post will detail overhauling the fuel system.
