filthyrich
filthyrich New Reader
9/18/15 12:58 a.m.
Hi guys, just want to share a 4BT swap build I did in an '04 Chevy Tahoe.
Full Album
"Bringing it back from the dead" Bought an 04 loaded Tahoe with a blown 5.3L. Previous owner hit a tree so it needed a bumper and hood as well.
"4 Bore turbo Aftercooled (4BTA)" picked up 2 4BTs with nv4500 transmissions as a package. Sold both Trans and 1 engine and paid for the whole package. Had a scrap 5.9L as a donor for things like exhaust and vertical oil filter housings.
Got a flywheel from Diesel Conversion Speacialists but after checking mating with the torque convertor realized they didn't mate, so I made my own holes. Problem solved
Welded the end of the 5.9l manifold shut and relocated the Turbo to leave room for the AC receiver dryer.
"Sending Unit" Dug into the vortec and got the Crank sending gear off the crank. Machined a pulley and heat shrunk it on to put in in front of the vibration Dampener.
Dry fit. So far so good.
Clearances were ok. Had to take little cooling fins off the front diff to make the oil pan clear
Tight but fit very well
Video series:
3.9L Cummins 4BT in an '04 Tahoe (Part 1)
3.9L Cummins 4BT in an '04 Tahoe (Part 2)
3.9L Cummins 4BT in an '04 Tahoe (Part 3)
FIRST START: 3.9L Cummins 4BT in an '04 Tahoe (Part 4)
3.9L Cummins 4BT in an '04 Tahoe (Part 5)
3.9L Cummins 4BT in an '04 Tahoe (Part 6)
3.9L Cummins 4BT in an '04 Tahoe (Part 7)
FIRST DRIVE: 3.9L Cummins 4BT in an '04 Tahoe (Part 8)
TUNING: 3.9L Cummins 4BT in an '04 Tahoe (Part 9)
RUNAWAY? 3.9L Cummins 4BT in an '04 Tahoe (Part 10)
Why I Put a 3.9L Cummins 4BT in an '04 Tahoe (Part 11)
"Biodiesel" Haven't tried it yet, next summer's project. Biggest cost of making biodiesel is getting it up to 55 Celcius. Its a perfect fit for the greenhouse as I don't have a green thumb--they are always black. Should be able to make Diesel at 40 C/L compared to $1.10 at the pumps
"Headrest Monitors" Got some headrest monitors for the kids.
Love the 2500HD clip. It was already white so I didn't have to paint it.
Got some nice rims from the neighbour kid. Dressed with lt285/75R16 BFG's
Gotta have the badging so people don't think I threw 6 rods in the vortec
"Engine Bay" Put all the shrouds back on cleaned her up
Very happy with the project. I am getting mid 20's mpg. This should bring my fuel savings from about 8000/yr down to about 4000. Hoping to save another 1-2000 with the biodiesel, as its not up and running yet. I would do it again in a heartbeat
Putting her to work. Tows like a boss.
The_Jed
The_Jed UberDork
9/18/15 2:16 a.m.
Nice!!
ebonyandivory
ebonyandivory UltraDork
9/18/15 6:10 a.m.
I have a 2005 with the 6.0 and this piques my interest.
Love the front end conversion too!
bgkast
bgkast UberDork
9/18/15 9:21 a.m.
Nice work. How is access to cylinders 3 and 4?
singleslammer
singleslammer UberDork
9/18/15 9:29 a.m.
In reply to bgkast:
Looks about as good as access to the rear cylinders in a Jag XJS
2002maniac
2002maniac Dork
9/18/15 9:56 a.m.
Sweet conversion! Are you running the original 4L60E trans? Do you expect it to survive?
I would love a rattly diesel in my 2500 burban.
filthyrich
9/18/15 11:11 a.m.
In reply to bgkast: Not bad at all. One bolt per valve cover. Everything has just been done to it including a valve set so it shouldn't need anything for 50 000km or so!
filthyrich
9/18/15 11:13 a.m.
In reply to 2002maniac: I added a massive cooler and keep a close eye on the temps. I pulled a 2004 Murano behind it on a tandem and the temp never got higher than 180*. Heat destroys everything so gotta keep it cool
java230
java230 Reader
9/18/15 11:56 a.m.
This is fantastic.
conesare2seconds
conesare2seconds HalfDork
9/18/15 7:58 p.m.
Wait, what? This build is bonkers. And very cool. Thanks for posting.
wheelsmithy
wheelsmithy GRM+ Memberand HalfDork
9/19/15 9:22 a.m.
Spectacular!
filthyrich
1/19/16 3:28 p.m.
Part 12: Back with a new update on the Tahoe! Finally got the Holset HE221w Turbo to try to get some more boost out of this beast. Watch more episodes of the 4BT Tahoe build
00:06 Holset HE221w Series Turbo
02:59 Turbo Assembly Overview
05:42 Priming The Turbo
06:43 Boost Test
07:11 Turbo Test Drive
09:50 0-80km/hr Test 1
10:30 0-80km/hr Test 2
jgrewe
jgrewe Reader
1/19/16 3:48 p.m.
This is awesome. I've had thoughts of putting one of these engines in something like a Jeep CJ.
I made bio for about 6 years and ran my Cummins powered Ram over 100K miles on 100% bio. Truck loved it, it kept everything in the fuel system clean and the oil didn't turn that coal black anymore. You will lose about 10% on your mileage but when it costs so much less you won't care. Come look me up here when you are ready to start brewing. As for the people that will say, "You'll hurt your engine!" My truck is about to turn over 300K miles and I just drove it to Ohio and back for Thanksgiving and never gave it a second thought.
My processor is up on a pallet rack right now because fuel is so cheap. If it starts going up again I'll pull it down and fire it up. My cost ended up being around 70-80 cents a gallon on average. There was a spike in methanol prices a while back but I never had more than a dollar a gallon when people were paying $4.50.
filthyrich
1/26/16 4:05 p.m.
Where are you from? I definately could definately use some guidance on making Bio. Thanks for the input!
crankwalk
crankwalk Dork
1/26/16 4:20 p.m.
I love everything about this build. As far as biodiesel goes, a modern VW with a DPF and sensitive HPFP I wouldn't go more than 20%. But on a 4bt , I'd run bio in a minute and not think twice. It doesn't care.
singleslammer
1/26/16 4:25 p.m.
In reply to filthyrich:
What sort of fuel mileage are you getting? (Side note, do you use US or English gallons?)
AntiArrhythmic
AntiArrhythmic New Reader
1/26/16 4:38 p.m.
My buddy has a dual tank setup in his F-250 Powerstroke with the grease car kit. He runs straight WVO with no problems. He's had it like this for a couple of years. He also has several diesel benz's that he runs on WVO. The heated oil runs thru a big ass oil filter before it gets to the engine. He does have to change the filter rather frequently.
BoostedBrandon
BoostedBrandon Dork
1/26/16 7:11 p.m.
This. This is why I love this nutball forum.
RossD
RossD UltimaDork
1/27/16 7:50 a.m.
So what kind of power output do you suspect you're making? Does the truck feel slower than when it would have had the Vortec?
golfduke
golfduke Reader
1/27/16 12:13 p.m.
This is amazing. Weight discrepancy of the longblocks/accessories between the 4BT and old 5.3? Estimates are cool too. My interest is heavily piqued. Would make an absolutely badass tow rig.
maschinenbau
maschinenbau GRM+ Memberand Reader
1/27/16 1:07 p.m.
I see you did a cat delete
java230
java230 HalfDork
1/27/16 1:11 p.m.
golfduke wrote: This is amazing. Weight discrepancy of the longblocks/accessories between the 4BT and old 5.3? Estimates are cool too. My interest is heavily piqued. Would make an absolutely badass tow rig.
From cummins 4BT:
745 - 782 lbs w/ oil
From interwebs: Iron Block vortec 580, alum 500.
In reply to maschinenbau:
I LOL'ed
filthyrich
7/25/16 11:25 a.m.
Part 13: Mileage Update - loaded up some trailers to see how the Tahoe handles it, then got some mileage numbers while on vacation. Watch more episodes of the 4BT Tahoe build
00:06 Trailer full of fencing
00:35 Getting Weighed
01:38 Trans & EGTs Towing 13000 lbs
02:15 Trans & EGTs Towing Silverado
03:02 Let's Figure Out Mileage
03:58 Tahoe Mileage Update
jgrewe
jgrewe Reader
7/25/16 8:31 p.m.
Sorry I didn't see the location question until this came back to the top. I'm in St Petersburg, Fl but I could get you making great fuel over the web no problem. Or if you come south like so many others from the Great White North we can do a bio fuel fantasy camp this winter.
One thing about Bio it will cloud at a much higher temp than dino-diesel and clog a fuel filter right up. Not a winter fuel for you for sure. So maybe June to Aug?
GKDDvzL2Owzod1WoJ4fdbiIN6ppD17r6fS6VxA4AkHi6JkpJWR3hBUt1ZBgo9jMB
