GridLife Spring Kickoff at Gingerman Raceway Recap
Things are busy at work so despite those overnight shipped brake caliper seals showing up by 11am I was at work till just after 3:30. Went home and swapped out the leaky seal, bled the brakes and loaded car on the trailer only to run into problems getting the splitter fitted up with some bolt interference that I didn't have when the car was on jack stands. Some cussing and grinder modification later it went on and we could get on the road. 3hrs out we stop and pick up 2 more friends and continue on another 3 hr drive to another friends house to stay the night, getting in around 12:30am. We visit for Thursday morning and head out after having lunch with a few more friends. Chicago strikes and it ends up taking over 2hrs longer to get to Gingerman than it should have and we arrive just before dark. Camp gets set up and the car unloaded. I make another once over of the car in the dark...good think I packed that light baton. Friday I don't have a session until after 5pm so I drive the car into town for a supply run and to get glue for the rear view mirror because it decided to fall off on the trip over...This is now the only test miles it got since the top end re-due. I decide changing the oil is worth while after the short trip as the cam should have broken in and might as well get that done. Around lunch I go to registration and get all my cool Time Attack stickers and a transponder which gives us something to do for a little while getting them all on the car. We spend a few hours driving around town and checking out garage sales. I pick up a portable air tank for $25
5pm rolls around and I grab a spot in group B as a complete guess about what lap time the car might have. I ended up near the front of the grid thinking I'm going to end up giving lots of point bys. Out lap goes well and I'm actually keeping pace with the cars ahead of me when starting the flyer. At this point I've already scolded myself for horrible lines on the out lap (I try to practice race line on out and cool down) and I have the worry about running the pan dry in 7/8/9 as that is common and I have oiling on my mind from Black Hawk Farms. Sure enough I run through 7/8 and 50 percent of the way through 9 I see the oil pressure twitch then drop to zero. I shut it down going into 10 and carry enough speed to get several car widths off course. I was worried about an oil down situation and kept to the outside of 10 until I could turn for the corner station. Once stopped the engine still turns over but I'm not seeing the oil pressure come up....."E36 M3". I get towed in at the end of the session and pull the distributor because I'm still not seeing any oil pressure while cranking. Throw the drill on it and within 5 seconds there's 60psi of pressure...."ok....so why wasn't there any while cranking?" I keep checking everything over and not finding any glaring reasons I suspect that it was just the pump not primed after going dry. After fighting to get the timing reset (since I neglected to pack the phasing tool) it fires right back up, no problems and running great. Lucky me I got away without damaging the engine. At this point I start try to look at options to continue the weekend from finding a used Accusump to driving hours to get a new on somewhere on a Saturday. At this point its time for a few beers while I try to think of a fix since getting an Accusump plus needed parts is going to be impossible on a Saturday morning. I start my walkabout with pockets full of beer and make it around far enough to spot Jabay and decide to stop and say sorry for partially ruining a session. He asks what happened and I end it with "unless I can find an accusump tonight or in the morning I don't know what can do other than add extra oil and hope for the best" to which he turns around and say that's the guy to talk to....well ok. So that guy is friends with the Doug Lane owner of Lane Performance which is only 30min away and he for sure will be willing to help! By the time I got back over to that trailer in the morning Doug was on the phone and lining up parts for me! We go over what I might need and he says "start driving down there, the stuff should be pulled from the warehouse by the time you get there". So I make the drive and wait maybe 10min tops for the parts and head back to the track after stopping to find a shorter oil filter to compensate for the sandwich plate thickness. I start the install with the help of my crew only to realize that I can't find my drill bits and sent them to town for some as continue the install. Finished up in just over an hour and thanks to that air tank I bought I'm able to properly setup the accusump pre-load.
Only missed one session. I grid up last in group B since I have no lap time and not sure where I'm supposed to be yet. Go out and push hard.....oil pressure in 9? Yes!!! A few laps later...fuel starve in 9....damn...and I was thinking about that while getting parts but forgot when we got back to the track. Got a lap in at 1:48.9 so at least I have a starting point.
Fuel up the car this time and go over the accusump parts again finding a small leak and fix that. I don't make any setup changes as I know my driving was the weak link that session and focus on what I know I was getting wrong and taking into account what the Garmin said I should be doing different. Get grid slot 6 in group C for the last session of the day. I work on what I want to do different on my out lap and then click off a string of 1:47 and 1:48 laps with a best of 1:47.25 with a car that's really loose in the slow speed corners. Was sliding through most of 2, 3, and 6 with a little bit in 9 (high speed) but not as much. Car felt fast but just couldn't get the power down on corner exit, brakes were better than ever with making me nervous on how late I could brake. Then the car just dies on the back stretch as I grab 4th???? coast in almost to hot pit but not quite. Won't restart or even act like it wants to. After a few minutes some friendly folks give me a push back to my pit. 10 minutes later the car starts back up like nothing happened...weird since the gauges didn't seem to be showing an red flags and after a good look over I can't find anything sticking out as the cause. After a discussion with a Ryan Finch about the car setup we agree that more angle of attack in the rear wing is good move to see if it cleans up the rear slide in 9 and maybe help in the low speed corners too. He also suggests a compression drop in the rear shocks. Decide to do my full chassis and brakes bolt check which was all good until a cracked front rotor... Now its after all the parts stores are closed, I check with the few corvette guys in my camp but they all have different size rotors despite to offer to cannibalize a broken C5. Time for those beers and walkabout again. Swing by another vette guy I know and he's willing to help but left his spares are the wrong size too.
I get up Sunday morning and decide on one more effort as the parts stores did not have anything in stock. I come across a C5 I hadn't spotted the night before and ask if they have an spare 13" rotors...And he did! Turns out it was Taylor Allen who's a sales rep for Hawk Performance and he had a used set of rotors as spares in his truck. I tell him I can give them back before I leave and he says you can keep them, he didn't even want anything for them. Thank you, thank you and I head back to pit and swap them just in time for first session of the day. Car dies on the backstretch during the first flyer and I coast into the pit again. I notice the IAT is reading higher than normal but 5min later it fires back up like nothing happened and I'm able to finish the session. With traffic I was able to do a few more 1:47 and 1:48 laps with a 1:47.24 as best lap. Same as evening before but the car felt better and "optimal lap" dropped to a low 1:45 from high 1:46. Top speed only dropped .1 mph so I added significantly more rear wing again to try to get the rear to work. On cool down lap I paid attention to the IAT and didn't come down more than a few degrees...odd. Next session in quickly heating up and degrading track conditions I decide to work on my brake zones as the main focus. I'm getting into a rhythm and doing 1:48 laps until I catch up to all the spec Fits. I just enjoy a lap or two following them before passing...at which point the car decides to die again....mid pass...so I stay inside of turn one and drive it off across the grass to pit out. Sit there for 2 min with the fan running and the car starts back up like nothing happened. Continue on and put in another 3 or 4 laps to end the session without problems. Best lap was a 1:48 something with me being way easier on it in the brakes zones and the extra rear down force reigning in the back a little more in the slow speed corners and enough to have the front slide first in 9 at high speed. Peak MPH dropped 3mph. Overall the car felt better and maybe I'd have still shaved time if I stuck with more aggressive brake zones but I was trying to be smoother with less lockup and less on power slides. The overall lack of rear traction makes me think there is a lot more in chassis setup and as much or more in my driving it in a way that makes it work. The car is better since last year we only did a 1:54-1:56 lap..I don't remember exactly. The brakes and corner entry is where the biggest gains came from, top speed was pretty much the same, corner exit seems "meh" which makes me think its not what it could be. Too much sliding for what those Falkens and my suspension changes should have done.
What the car is doing really well compared to last year is changing direction. With the rear setup it rotates in better with trail brake but then rotates even more upon throttle application..until the back tires start sliding. This was real noticeable on 6 where I would brake before 5 coast through then just a touch of brakes to start the 6 turn in then it would tighten its radius going back to throttle. Enough that I had to take wheel angle out in order to track out on exit all the way.
I'll be looking through the EFI for a safety or something that I may have missed that could be causing the random engine off scenario.
This weekend I'm going to BIR for Proving Grounds Part 1 2021 in which I'll have Autocross, drags, HPDE, and Standing Start Shootout. Plan is to largely use this weekend as test and tune with the various disciplines. I'm grateful for the help Doug and Taylor provided which is why I have a operable car going into this weekend and not in a mad scramble for parts.
