Time to update the thread again. Looks like another two steps forward, one step back deal. I needed to put in a new air filter, plus I really wanted to change out the washer nozzles for the headlamp washers. While I was at it I also got a front plate mounting kit - NV is a state that normally requires a front plate, but usually you don't get into trouble if you don't have a plate mount. However, occasionally missing front plates are used as a reason to pull people over. Anyway, we have a small pile of parts, bargain at only ~$420:
The washer nozzles are $180 apiece at Pelican if you were wondering about the price tag.
The nozzles are notorious failure points because the jets tend to blow out after a while, leaving the whole thing look like this:
So you unlock the headlight with the official 996 headlight unlocking tool:
Pull the whole thing out and end up with this:
The driver's side nozzle clips on the supply tube, a bit fiddly to remove but not a big deal:
Passenger side needed a bit of heat to get the tube off, again, not a big deal:
Driver's side went well, we now have jets again:
Unfortunately the whole car currently looks like this - while mounting the passenger side headlight is not a big issue, it turns out that it doesn't want to plug into the wiring correctly. The Litronic have two connectors at the back. One "regular" one that you just connect/disconnect manually and one that the light unit connects to by itself as you slide it home.
The problem is that someone's been in there before and the connector itself is loose. It's clamped into a (plastic, of course...) upright and held in place by a yellow clip, but before the clip is, err, clipped home, the connector is supposed to be hooked into its mount at the top. Well, mine isn't and I can't get the yellow clip to disengage to fix it. Unfortunately that means the connector on the light doesn't engage properly and I have no passenger side headlight. Ah well, at least I found the reason for the occasional intermittent headlight:
I ended up asking over on Rennlist if anybody has any tips on removing the yellow clip - it feels like it's locked into place and I need to find the right area to depress to unlock it, but I can't see enough even with a mirror to figure out how to do this. I hope someone knows, otherwise I'll have to take it to my Porsche mechanic in its current one-eyed glory and see if they can fix it.
Of course, that's exactly why I'm not super keen on working on my DDs and prefer to just wrench on my projects.
At least the air filter change went almost without a hitch, other than the snorkel on the left being held in mostly by luck and the engine lid:
The mounting holes in the bottom half of the airbox are damaged so it just flops about. As stuff like this tends to annoy me I'll try to bag a good used airbox on ebay and switch it out.
Also looked like I got my money's worth out of the air filter:
