pres589 (djronnebaum)
5/20/19 10:37 p.m.
I'm really curious what engine and trans setup you do on this one.  You've got what sounds like a complete set of engine accessories as long as all brackets mate up to whatever heads you end up with.  Could do worse than a 350ish iron-block SBC, whatever aluminum heads you can find on the cheap, and a 200-4R behind it.  But that's just one way to skin this cat and there's a ton of other methods as well.
Good score, and good luck!
Madhatr
Madhatr Reader
5/22/19 1:48 p.m.
Thanks! Right now I am looking at useing the SBC and 700 R4 out of this car 84 vette that I parted out about 5 years ago:
I cut the car up for the suspension for another project
I paid $660 for the entire non running roller car (600 + 10% buyer fee) but that was back before Vettekarts and before I knew about the challenge, so I don't think the paperwork has survived.  I will need to figure out FMV and go from there to see what the best plan is.
I checked the casting numbers on the iron heads and they should be 1.94(?)/ 1.50 or the 2.02/ 1.60 valves. I have not opened it up yet to check condition, but I do know the 700 R4 was shot when I got it.
nkOduLfnE6TX0OcNZjWC6nXEuRcvQJBiWYzR3zZMNyHWqyf4eMs50lnljcxu5d2Q
