1 ... 3 4 5 6 7 ... 9
MichaelYount
MichaelYount Reader
5/15/13 5:44 p.m.
jakeb wrote: I am already running a 15mm spacer...might have to go to a 20mm to get everything to clear. First step I will try spacing it out another 5mm with washers and see where I "sit"
Yup - that's how I determined which spacer to get -- used my micrometer to stack fender washers (equal thickness stacks) on 3 of the lugs and test fit. My perch was touching the tire and the weld on ring that supports the threaded sleeve was touching the edge of the wheel.
jakeb
jakeb Reader
5/15/13 7:37 p.m.
Just showing off the rear tires....
Awesome to see wheels back on it...
Sky_Render
Sky_Render Dork
5/16/13 7:45 a.m.
What wheels are those?
Bobzilla
Bobzilla UberDork
5/16/13 7:48 a.m.
Sky_Render wrote: What wheels are those?
Large ones.
jakeb
jakeb Reader
5/16/13 8:07 a.m.
Apex EC-7
Front 18x9.5 Rear 18x10"
jakeb
jakeb Reader
5/21/13 5:39 a.m.
Rear flare mock up...
jakeb
jakeb Reader
5/29/13 8:38 p.m.
I want the flares to look stock so lots of measuring and planning before cutting.
I want to keep the edge where the bumper comes to so everything flows like it was stock.
Front flare at the edge where the bumper will meet. The new flare might get cut slightly higher but it's closer.
It will match up on the back side under the trim...or right at the top edge
The top of the new flare still needs to be smoothed out to a nice circle and then the e36 fender will get cut and start welding in the new one. The entire passenger side will get done..front and rear and then repeat on the drivers side.
jakeb
jakeb Reader
6/1/13 8:44 p.m.
More fitting...
Rear...
Somewhat setting on the ground...can't go all the way becasue the rear fenders are not cut out so they fit the tire.
jakeb
jakeb Reader
6/4/13 9:29 a.m.
The drivers side flares are mocked up to match the passenger side. Still a little bit of trimming and then they can get cut out and welded.
bumper and everything is just setting on and nothing is tightened up. I was trying to get a picture showing how the flares look from the front. Sorta hard to do...
Picking up the power coated brake calipers this afternoon and will update when I have them.
jakeb
jakeb Reader
6/5/13 7:39 a.m.
I should have put something in the photo to show size...they look small on their own but they are far from small.
The plan was to use powder to make the ///M but the powder coater did not feel comfortable doing it that way and getting a good results. So they will be done in vinyl. This is the type of vinyl used on signs, trailers, etc so it will handle a lot of abuse.
They will get put on once everything is together.
Rear
ransom
ransom GRM+ Memberand UltraDork
6/5/13 8:55 a.m.
jakeb wrote: The plan was to use powder to make the ///M but the powder coater did not feel comfortable doing it that way and getting a good results. So they will be done in vinyl. This is the type of vinyl used on signs, trailers, etc so it will handle a lot of abuse.
Given your general attention to detail, I feel silly asking this, but... Is that vinyl really up to the heat of a brake caliper?
More usefully, if so, where do you get it and what do I ask for?
jakeb
jakeb Reader
6/6/13 6:38 a.m.
The coater says it is. I will check the specs with him
jakeb
jakeb Reader
6/9/13 11:55 a.m.
Time to start cutting...
jakeb
jakeb Reader
6/11/13 3:49 p.m.
thanks!
More cutting...
Inner fender left and it will get bent to match the new flare
Fronts tacked...
This picture really didn't turn out for some reason...
The drivers side rear is done as well but for some reason I didn't get a pic. I'll get one and post tomorrow. Today is my birthday and it has been a great day in the garage.
ransom
6/11/13 3:50 p.m.
Happy birthday, and nice work! That's looking terrific!
jakeb
jakeb Reader
6/11/13 8:21 p.m.
thanks man! Yeah I am VERY happy with it. It's impressing me even.
jakeb
jakeb Reader
6/12/13 12:13 p.m.
Lots of little tacks...I go around each flare. Let it cool for a bit and do it again. To keep any warpage to a minimum.
Fronts still need more
jakeb
jakeb Reader
6/13/13 10:30 a.m.
I left part of the inner fender and then will bend it out to match the new flare. Either weld or use panel adhesive to hold the two layers together.
Picture isn't very good as the flash on the camera went off and picked up all the dust, etc
All the welds around ground down
jakeb
jakeb Reader
6/18/13 7:50 a.m.
I was away for the weekend but back at it today.
Camaro front driveshaft section showed up....going to have this combined with the BMW shaft. BMW bottom...Camaro top https://lh3.googleusercontent.com/-K32Na08lFsw/UcBVaD_CVPI/AAAAAAAAG7Y/28kIa_devOQ/s640/IMAGE_47.jpeg
I would say these are pretty close.... Camaro
BMW
Front section
Rear section
More updates later
jakeb
jakeb Reader
6/18/13 4:24 p.m.
First coat of filler (duraglass) going on the flares
Cruise control actuator is being removed because it is a Drive by wire throttle body. Brackets are coming off too...holes will be welded up and then the entire bay will get repainted.
e_pie
e_pie HalfDork
6/18/13 4:48 p.m.
Subscribing to this, awesome build.
jakeb
jakeb Reader
6/20/13 12:16 p.m.
Another mid day update...
Engine is back out:
ABS pump location
ABS pump brackets
Engine bay getting ready for some fresh paint
pulled the old hood liner
More flare work
xflowgolf
xflowgolf HalfDork
6/20/13 12:43 p.m.
great stuff. love all the updates, keep them coming!
jakeb
jakeb Reader
6/24/13 6:46 p.m.
Brake lines to ABS pump all extended...and off to powder coat
Jigged the trans mount before going off to powder coat
Engine mounts are off to be coated as well and then they will get jigged...the powder coater I use also does Lathe work and he is making me a plug to make the engine mount jig.
Passenger side header jigged and ready to weld
header off...
Drivers side
Both together...Once the headers are all welded up I will add a locator for the vband and collector
jakeb
jakeb Reader
6/25/13 8:45 p.m.
New location for the heater valve
The bracket that will hold it to the inner fender...this will get painted or coated
The LS3 uses a Drive by Cable throttle body so the stock throttle pedal was removed.
New pedal will go somewhere in this area...
I really need to roll the car off the lift to place the pedal. I can't get the door open enough to get down in the footwell.
Getting the engine bay ready to paint.
Fresh Paint....
3VgISpvyDEjuabRd30RD0z8chRlIRDGgl3u7Gn778Y5Fwx7U3AXAkDp7GEAzio1C
