1 ... 15 16 17 18 19 ... 135
ATSAaron
ATSAaron New Reader
1/30/19 4:38 p.m.
In reply to mke :
My wheels are Autostrada Modenas. I have adapters/spacers on there to make them fit.
I'm running 622 whp/750 flywheel hp based on the drivetrain losses I have seen from other stock Ferrari's I have dyno'd. It's a Frankenstein motor with parts from about seven different dead 308/308i/308QV/328/348 motors. I've got 348 heads, 11.5:1 compression, big cams, Link G4+ Storm ECU, and a Precision ball bearing 6466 turbo at 1.15 bar/16.5psi of boost.
Here is another shot of the wheels. I added a 288 style front airdam, foglights, and grille too.
Aaron
mke
mke Reader
1/30/19 6:34 p.m.
mke
mke Reader
1/30/19 6:39 p.m.
mke
mke Reader
1/30/19 6:50 p.m.
mke
mke Reader
1/30/19 6:55 p.m.
wheelsmithy
1/30/19 7:33 p.m.
I love it when GRM spawns internet madness.
I also love the Ferrari madness. Well Done!
mke
mke Reader
1/30/19 7:37 p.m.
Madness it is.
Can you tell it's too cold out in the shop for me to do any actual to work....
In Greek
https://www.drive.gr/news/tuning/pos-na ... -v12-video
mazdeuce - Seth
mazdeuce - Seth Mod Squad
1/30/19 8:34 p.m.
This is how internet automotive fame goes. It's a fun ride. Enjoy it.
Cassius
Cassius New Reader
1/31/19 9:25 a.m.
3SDM 0.05's look similar aswell. Quite cheap also, probably not the same quality as stock Ferrari wheels but.. still kinda similar :)
https://www.3sdm.co.uk/cast-wheels/cast-005/
mke
mke Reader
1/31/19 10:28 a.m.
In reply to Cassius :
That's not bab and quite cheap...they don't have the right bolt pattern or offests or wide enough rears though :(
I see a forged 3 piece version, I'll need to request pricing
Here's the 55 rear with a new center....I need to check some dimensions but it should be close....not sure I can buy the alum for just making the center as cheap as the cast wheels though.
Addicted
Addicted New Reader
1/31/19 10:53 a.m.
If you're looking for wheels have you thought of speaking to Brian or Jason at Rotiform Wheels in LA? I know they did the custom made wheels for the Mitch Buttons wide bodied 328 and making one off  sets of modern size wheels in old styles is their forte..
Darchangel
Darchangel New Reader
1/31/19 11:52 a.m.
mke said:
Concerns about Fram filters noted and thank you for the information...but can we leave it here?
Here is what 308 wheels look like (internet pics)
Here are a couple pics of the ferrari F550 wheels I have (also internet pics)
Here is something I stumbled on...its a land rover I thing.  The shape of the rim itself looks a whole lot like the 550 rim, but the spokes are quite similar to 308 and lind of what I'd endup with if I make new hubs for the 550 wheel, but mine would be set back into the rim an inch of 2.
Not bad and not real hard to do.....I'll need to CAD something.
Don't know if you've found this place but its a decent free online CAD...everything is public but its free and works pretty well so....
https://cad.onshape.com/signin
I think you might be interested in Simmons wheels from Australia:
http://www.simmonswheels.com.au/wheels.php?series=simmons-b45-series
15 Inch Simmons B45
3-piece, so can be built to spec.
There's another wheel I see on Aussie cars that's similar, but with a wider spoke - much more like the 308 wheels, but I'm having trouble finding it. I thought it was Simmons, but I don't see it on their site.
Edit: that said, you making your own would be right in line with the rest of the build.... :)
RoddyMac17
RoddyMac17 Reader
1/31/19 12:00 p.m.
You could also try contacting Image Wheels in the UK:  ImageWheels
Darchangel
1/31/19 12:10 p.m.
Not the ones I was looking for, but here you go:
http://www.imagewheels.co.uk/billet-11-alloy-wheel/
CNC Billet Alloy Wheels - Image Wheels
Cast version: http://www.imagewheels.co.uk/f40-alloy-wheel/
Image Wheels Alloy Wheels F40
Bit pricey.
Darchangel
1/31/19 12:10 p.m.
Hah! Beat me to it.
Darchangel
1/31/19 12:13 p.m.
I think the HRE 505 was what I was looking for:
https://www.hrewheels.com/wheels/vintage-series/505
Edit: Holy crap, $2000 *each*.
Edit 2: apparently, this model was originally made as the Hayashi Racing Palace, bu in smaller sizes prevalent back in the day:
https://kyushashoes.com/product/hayashi-racing-palace/
mke
mke Reader
1/31/19 12:14 p.m.
In reply to RoddyMac17 :
I  like hose and they are ALMOST sort of in budget and was planning to get those....but the guy annoyed me so they're off the list.  Nice looking though.
Budget is really the driver.....anything over free is suboptimal.
mke
mke Reader
1/31/19 12:15 p.m.
Exactly....lots of really nice options and custom stuff I can't even pretend to be ably afford.
Darchangel
1/31/19 12:22 p.m.
The Autostrada Modena is another one that's the right style:
https://www.google.com/search?q=autostrada+modena&source=lnms&tbm=isch&sa=X&ved=0ahUKEwjK672q0ZjgAhUIS6wKHYioBzkQ_AUIDygC&biw=1467&bih=836
A bit better at about $2K used on eBay, looks like, but still $$. I guess anything that *looks* Ferrari is priced like Ferrari...
mke
mke Reader
1/31/19 12:54 p.m.
In reply to Darchangel :
The problem with used modular wheels is there are literally hundreds if not thousands of size options....finding the right ones would be quite a trick!  My fronts are basically stock so those might be something that could be found used....not sure though as the 430 rotors move the calibers out so stock offset would probably not work....used is tough.
vwfreek
vwfreek Reader
1/31/19 1:57 p.m.
Another option would be to make your own 3-piece wheels. Cut the OEM wheels down on a lathe to use as centers, drill a few holes, and bolt on aftermarket barrels.
mke
mke Reader
1/31/19 2:17 p.m.
In reply to vwfreek :
If I had OEM 308 wheel....
mke
mke Reader
1/31/19 2:21 p.m.
Here's a little refinement.  I the first version the hub was dished which probably won't work up front and needs a pretty thick chunk of billet.  This one uses a flat center and a spacer on the back to set offset..1" or 1.125" thick billet will do  and WAY easier to make. on the equipment I have.  I'll need to get real numbers for the front before doing anymore then adjust the rear to be a good cosmetic match I think.
86IROC
86IROC New Reader
1/31/19 3:22 p.m.
I've been reading your thread for the last 2 days and the great pride I felt in rebuilding the carbs on my 76 GL1000 is gone now.
I can't believe I had some advice to offer you but I do. :)
I highly recommend ceramic coating on your headers.
I had the headers on my IROC coated and the under hood heat was reduced significantly.
mke
mke Reader
1/31/19 6:30 p.m.
In reply to 86IROC :
Probably the right place to start and see how it does.
56gbcdEZSYkEr9nVKTyHwp1LU4mgBC5BCgiuj1lGSt4wVJuRIBEuMGrLIBk382Kw
