RichardSIA
RichardSIA Dork
4/10/23 1:06 p.m.
I guess I am committed to doing this, just paid $68.86 for a NIB Sachs Samurai flywheel.
pres589 (djronnebaum)
4/10/23 1:57 p.m.
When you discover you're going through hell, keep going.
RichardSIA
RichardSIA Dork
4/10/23 2:15 p.m.
As rough as the body is (Still great compared to many!) The engine swap has to be done first to help with motivation.
RichardSIA
RichardSIA Dork
7/25/23 1:14 a.m.
OK, Geo engine is going into a sandrail, sammy trans to MI.
I have a 1098 and ribcase for the Morris, they bolt right in.
Running out of time for doing things the hard way.
jfryjfry
jfryjfry SuperDork
7/25/23 10:26 a.m.
A running, stock car > perpetual project
TurnerX19
TurnerX19 UberDork
7/25/23 11:20 a.m.
In reply to jfryjfry :
A running stock Morris Minor is a perpetual project. Everything that breaks or wears out is available, and to keep the volume of parts sales up the quality of the repro parts is god awful except for engine and gearbox internals.
jfryjfry
jfryjfry SuperDork
7/25/23 3:03 p.m.
I, too, have a morris minor project that has stalled out for about 15 years.  Ugh....
RichardSIA
RichardSIA Dork
7/25/23 7:08 p.m.
Mine is not stalled, I am gathering parts.
It does have to wait until the Europa is on the road.
There is a slim chance it may end up with a T5 trans.
Pretty sure no A Series on earth could break a T5.
TurnerX19
TurnerX19 UberDork
7/25/23 9:19 p.m.
In reply to RichardSIA :
It's not the gearbox, it is the driver..
RichardSIA
RichardSIA Dork
7/25/23 9:47 p.m.
T5 for overdrive.
Piguin
Piguin New Reader
7/26/23 5:55 a.m.
Good to see this is moving forward, no matter the engine.
What prompted the change in direction? Wouldn't a T5 conversion take about the same amount of fabrication?
RichardSIA
RichardSIA Dork
7/26/23 10:11 a.m.
T5 would not require as much work.
No change in engine mounts, radiator, etc. and would appear stock.
I may find a 1275 for it.
Since the T5 has a removable bell the thought is to cut a T5 bell and a Rib-Case trans.
Weld the pieces for a "Simple" adapter.
Common way to go down under.
My Morris is a PU, so it has an actual frame and removable cross member.
WLW9xr8bTLVL1geZqNPjibmuyutUaoMGZgrm8QASAjPTmbWCNeRDOhd8uUcoFOoe
