Ok, time for Adventures in Bump-Steer!
I'm not totally sure what I'm doing here, but I'll wing it.
My concern is that a shorter TR6 rack will create a bunch of bump steer, where the longer 2000/2500 Saloon rack will be fine. Data is required.
First things first, I hard-mounted the bare rack in the clamps with 3d printed bushings. This will let me hold everything static and just look at the bump-steer movement. I centered everything up, and made an initial mark for this version. To simulate the wider rack, I just moved this rack out 7.5 mm. I'm only looking at one side, so that should be fine. All these pictures represent the "wide" version like the factory rack.
Here's the overall setup - hack-tastic!
A note: mounted here is one of the old inner tie rods. The TR6 parts are much shorter - like an inch - and would not even reach.
Here's full-droop - note the distance on the janky level / square combination:
Here is roughly full-compression:
Doing some careful measurement, there is about 1/2" of toe-out rotation between full-droop and full-bump. The pointer-arm length is 17" long, so that amounts to roughly 2 deg bump steer.
Interestingly, it is basically the same with the "wide" setup and the "narrow" setup.
What I don't know is how much the camber change is affecting this. If the hub naturally swings in 1/2" over it's travel, then it would seem I'm totally fine. I'll need to do a little more measuring and messing to get a better feel for what the geometry is doing.
General question to those who KNOW, is 2 deg bump steer OK? Bad? A disaster?
