1 2 3 4 ... 10
petegossett
petegossett GRM+ Memberand UltimaDork
8/17/16 5:54 a.m.
In reply to nocones:
Awesome progress! Are you driving Russ' car at Lincoln?
nocones
nocones GRM+ Memberand UltraDork
8/17/16 1:25 p.m.
Nope codriving with John Li.
nocones
8/21/16 12:34 a.m.
Rear bulkhead is complete. It's made of way to many small fiddly pieces. Here you can see the hole I left for diff removal.  photo IMG_20160817_242809173_zpsfembeqir.jpg
And here it is complete with the cover. I riveted in small pieces of steel to the aluminum to reinforce the edges where joints were and provide a surface for he TEK screws to seat in.
nocones
8/21/16 12:42 a.m.
And finished the scuttle panel. This worked really well and was surprisingly simple/straightforward. It is 3 pieces that overlap with the stock firewall panel. I used my friend the TEK screw to secure the aluminum. From the frontside it looks smooth.  photo IMG_20160821_241024545_HDR_zpskhtc9i49.jpg From the back to can see that it is floating in front of the frame by about and inch.  photo IMG_20160821_241040954_zpsfidhkexq.jpg The only remaining aluminum panels will have to wait until the car is more assembled. The tunnel top requires installed engine and the brake cover requires installed/adjusted brakes so I am done with aluminum panels for now. Next shop time will be suspension reassembly the brake master cylinder install. I will then work on brakelines. So probably boring pictures for a while.
petegossett
8/21/16 12:35 p.m.
Very cool Daniel, It'll be awesome when this hits the course again. Was it around '01 when you first yanked out the stock drivetrain?
nocones
9/10/16 4:23 p.m.
Back from nationals. Overall I Had a good trip. I wish I had the MG but it was nice seeing the D/Emod people and their cars. I got to talk to many of them and see the competition. Everyone was nice and approachable and I'm excited to join the class. Next year I will be there with the MG for sure.
I drove a C5 Z06 in AS. Given that I had only driven the car 1 event (my only event this year) before Nationals I am pleased with how I did. I had 6 clean runs and was only ~.75 seconds out of trophies.
Work on the MG continues. No pictures today but I do have an update. Brake lines are ran and the system is bleed. I final assembled front and rear suspension so the suspension is ready to go. I've also replaced the flywheel surface (racing beat aluminum flywheel with replaceable insert) and final assembled the engine/trans. Next up is to assemble the intake and plug all the holes in the engine.
Remaining prior to running is.
1. Install engine
2. Finish weld exhaust / install.
3. Run all electrical
4. Plumb fuel system.
5. Install radiator/oil cooler.
6. Fill with fluids.
7. Install seats/harnesses. 8. Align.
9. Go Racin
petegossett
9/10/16 11:11 p.m.
Think you'll get it on course this season, or aiming for next spring?
nocones
9/14/16 11:18 a.m.
And now boring pictures.
I got the accelerator all hooked up. I ended up using a Miata pedal bent with the original MG pedal welded on. I attempted to purchase a 1996 Miata throttle cable from O'Reilly and ended up with some wierd thing with a 2 hole rubber flange and metal bracket. It's a Pioneer CA-8896 and is a high quality cable but it most definitely is not for a Miata despite it being listed everywhere as for a 1994-1997 Miata. But I'm not building a Miata so I was able to use it. Both ends of the cable as well as the sheath/cable length were correct so I was able to use it to attach my Miata Pedal to my RX-7 throttle.
 photo IMG_20160914_065915952_zpss8lsotrc.jpg Great Success. The pedal is a bit long/wierd shaped so the motion is a little strange. I will likely eventually do something different to do a floor hinged pedal but for now it works and It seems heal/toe will be doable.  photo IMG_20160914_065903200_zps5qbwimap.jpg See I promised boring pictures.
nocones
9/14/16 9:09 p.m.
Has anyone ran fuel lines through a tunnel with a floor? I'm wondering if I should run the lines through a metal tube that runs the length of the floor pan. That way if a line were to leak the outer tube would direct fuel away from the tunnel. Seems safest but not sure if necessary.
Dusterbd13
Dusterbd13 PowerDork
9/14/16 9:40 p.m.
Overkill. But the way I would do it. Fire bad that close to my jewels.
nocones
9/17/16 12:22 a.m.
 photo IMG_20160916_235541153_zpsdwiwsfos.jpg I ran the hardlines. I built a sleeve that I ran diagonally on the bottom of the tunnel. The engine is ready to go in now which is the next step. Which will be wierd.
nocones
9/18/16 10:03 a.m.
 photo IMG_20160917_230137314_zps5jcxog3h.jpg Fuel system is complete. I have no idea how to run the vent so I did what the internet showed. Fuel pump mounting bracket is just some 1"*.125 strip welded to the bottom of a tube.  photo IMG_20160917_230159263_zpsagqull6i.jpg  photo IMG_20160917_230205514_zpsbra79ncg.jpg
Engine is in but immediately has to be removed because I forgot to install the header. Despite my best efforts the header must be installed from the engine bay. Maybe a future improvement will be to fix that. Looking at final clearances I will have to put in a access cover on the driver's footwell to allow for sparkplug service and oil cooler install. I can live with that I'm just happy the engine actually fit.
Thinkkker
Thinkkker UltraDork
9/19/16 8:57 a.m.
nocones wrote: I drove a C5 Z06 in AS.
I drove a C6 Z06 in AS and was only .047 out of trophies. I need to speak up more out there ;)
Also, I really want to see this car together and running.
einy
einy Reader
9/20/16 6:34 p.m.
Digging the fuel line runs ... very nice work! Been there myself on Exocet project, and gotta say, those are no fun at all to hand bend!! Your work on this project is truly a joy to watch progress!
nocones
9/21/16 9:30 a.m.
 photo IMG_20160920_234943015_zpsv2ebrdoa.jpg Someone left this bucket of Doritos in my engine bay. Now with 1000% more header installed.
petegossett
9/21/16 10:08 a.m.
You're really kicking ass now! I still can't believe how far you've brought this car, and envy your talent, patience & persistence to keep at it for all these years.
java230
java230 Dork
9/21/16 10:08 a.m.
Damn that makes a rotary look big. Looking good!
nocones
9/24/16 11:25 p.m.
 photo IMG_20160924_230259243_zpsfrupfmei.jpg Mocked up a fake instrument cluster to see how I wanted to lay things out. Electrical will start as soon as I fab this panel. The 4 gauges are Tach (on order), Innovate MX-L Wideband, Oil Pressure, and Water Temp.
More tomorrow.
NOHOME
NOHOME PowerDork
9/25/16 7:22 a.m.
Having a hard time reading what the rev limiter is saying?
MrJoshua
MrJoshua UltimaDork
9/25/16 8:13 a.m.
Is the exhaust running through the tunnel with the fuel lines?
petegossett
9/25/16 8:49 a.m.
That steering wheel.
nocones
9/25/16 9:15 a.m.
For the wheel, On the Locost forum there is a post showing how I built it. It was a proof of concept that has stuck around. It has no metal rim which I should have included but was not expecting it to turn out so well. I will make a more "proper" one in the future and have a separate 12" wheel for racing.
The exhaust runs out the side and then back under the car in front of the rear wheel. I anticipate needing 2 mufflers based on a local running a 13b ironically in a MG. That is the way he routed his and it works well. I will fab up a heat shield for the side muffler.
As to the Tach this picture is a bit clearer. Maybe will have to disassemble the actual tach and do an overlay.  photo IMG_20160924_230317183_zpsyjgkm0mj.jpg
Thanks for all the interest. It helps keep me motivated to know other people are engaged.
nocones
9/29/16 9:40 a.m.
 photo IMG_20160929_240939287_zpsghmbumbi.jpg And now cardboard becomes metal. I must go wire stuff now.
jfryjfry
jfryjfry Reader
9/30/16 4:05 a.m.
nocones wrote: For the wheel, On the Locost forum there is a post showing how I built it. It was a proof of concept that has stuck around. It has no metal rim which I should have included but was not expecting it to turn out so well. I will make a more "proper" one in the future and have a separate 12" wheel for racing.
can you post a link???
nocones
10/1/16 5:19 p.m.
In reply to jfryjfry:
http://www.locostusa.com/forums/viewtopic.php?f=22&t=13470&p=138853#p138853
Here is the thread. I didn't include a rim so it's all wood which makes it "bad". It's a rim for show at this point.
1 2 3 4 ... 10
y8kMzYAKKhJVUFIGm0JB4HVIqRCwMxe5jk6Z4ihfLSaej1tG8jqS4l9dKotfxMJR
