1 2 3 4 5 ... 9
NoPermitNeeded
NoPermitNeeded Reader
12/18/16 12:33 p.m.
Ben_Modified wrote:
Lof8 wrote: Ben, you build some awesome stuff! Do you ever sell off the completed projects or just have em piled in a shop?
Thanks, I do sell them from time to time. The V8 Bug Volksrod will be sold when it is done and road tested for a couple months.
How much are you selling it for?
Ben_Modified
Ben_Modified Reader
12/18/16 1:30 p.m.
I'll have to break out the box of receipts to figure that out!
Ben_Modified
Ben_Modified Reader
12/18/16 1:33 p.m.
Frame progress
<img src="20161218_112147_resized_1" /> <img src="20161218_112137_resized_1" />
My Project Vidoes are here:
Ben_Modified
Ben_Modified Reader
12/19/16 4:10 p.m.
Freed the engine from the bike frame
<img src="20161219_154437" />
My Project Videos are here:
Ben_Modified
Ben_Modified Reader
12/21/16 8:51 p.m.
Making up cross members and engine mounts
<img src="20161221_172930_resized" />
Some temporary bracing in place
<img src="20161221_173007_resized" />
Ben_Modified
Ben_Modified Reader
12/21/16 9:25 p.m.
Jerry From LA
Jerry From LA SuperDork
12/22/16 6:04 p.m.
Do you have to re-baffle the oiling system since the motor is now oriented sideways? I remember former GRM tech editor Per Schroeder having a problem with oiling in a Kawasaki engine on a B Mod car since it now corners on a relatively flat plane.
Ben_Modified
Ben_Modified Reader
12/22/16 8:41 p.m.
Not too worried about it. If it is a problem, the dwarf car racing folks have custom oil pans and floating pump pickups
Ben_Modified
Ben_Modified Reader
12/24/16 5:08 p.m.
Progress on the engine mounts
<img src="20161224_165531_resized_1" /> <img src="20161224_165509_resized_1" />
It was too hot to install the rubber bushing here
<img src="20161224_165454_resized_1" /> <img src="20161224_165911_resized_1" />
Also installing a brace from the bottom of the rear subframe to the rest of the chassis. I will cap of the open ends
<img src="20161224_165548_resized_1" />
Braced the body for the rocker panel removal
<img src="20161223_165636_resized" />
My Project Videos:
Ben_Modified
Ben_Modified Reader
12/25/16 5:51 p.m.
Started separating the body from the make shift chassis. Found a stash of walnuts in both rocker panels
<img src="20161225_133057_resized" /> <img src="20161225_132733_resized" /> <img src="20161225_132724_resized" />
My Project Videos
Ben_Modified
Ben_Modified Reader
12/26/16 8:42 p.m.
The body is off
<img src="20161226_150940_resized" />
Anybody need some cushman truckster to autobianchi wheel adaptors!
20161226_160503_resized <img src="20161226_160513_resized" />
Fitting the body to the new chassis
<img src="20161226_163827_resized" />
www.BenModified.com
Ben_Modified
Ben_Modified Reader
12/27/16 6:28 p.m.
<img src="20161227_085323_resized_2" /> <img src="20161227_092813_resized_2" />
My Project Videos
Ben_Modified
Ben_Modified Reader
12/28/16 6:08 p.m.
<img src="20161228_160517_resized" />
Took the body back off again and trimmed out all of the unnecessary metal. Also cut out the inner rear wheel wells so that the tires will fit
<img src="20161228_160557_resized" /> <img src="20161228_160613_resized" />
<img src="20161228_161820_resized" />
Also ground off a ton of undercoating..what a mess. Time to start on the cage and get to welding the body and chassis together.
My Project Videos
brad131a4
brad131a4 Reader
12/28/16 7:50 p.m.
Ok so how much room is there between the motor and seating area?
thestig99
thestig99 HalfDork
12/28/16 9:52 p.m.
"Don't expect any rapid progress on this build."
Five weeks later, dropping the body onto the newly built chassis.
Keep it up!
Ben_Modified
Ben_Modified Reader
1/13/17 6:50 a.m.
Been waiting on parts. I ordered several spicer pieces to make a driveshaft with a slip joint in the center for the rubber mounted engine. Unfortunately, when the male and female joint are together, none of the spline engagement produce a union in which the yokes are in phase. I called Spicer yesterday but got nowhere. Calling again today and hoping for a different rep. In the meantime I also discovered that one of the flange yokes has measurements that are nowhere near published specs despite the part number that is stamped on the yoke.
<img src="20170112_161727_resized" /> <img src="20170112_161708_resized" /> <img src="20170113_051243_resized" /> <img src="20170113_051341_resized" /> <img src="20170113_051331_resized" />
Jerry From LA
1/13/17 3:59 p.m.
Ben_Modified wrote: It is only a 600cc but it will do for now...Also found the perfect set of tires, 165/50-14. Same overall diameter as the oem 12's and V rated for $48 each!
V-rated, huh? Ben, you are a real optimist!
Ben_Modified
Ben_Modified Reader
1/14/17 1:58 p.m.
The new 1310 series rear yoke has the right bolt pattern for the Miata diff but the bolt holes are drilled for 1/2" bolts and the Miata 5/16" (8mm). Machined some insert to take up the slack.
<img src="20170114_094426_resized" /> <img src="20170114_105541_resized" />
Videos are Here:
Ben_Modified
Ben_Modified Reader
1/17/17 6:19 p.m.
Machined a bushing to align the driveshaft and diff flange. The original Miata driveshaft has a male pilot bushing but the new spicer 1310 series has a female. This sandwiches in place. Started with a 2" dia round bar
<img src="20170117_151933_resized" /> <img src="20170117_172443_resized" /> <img src="20170117_172521_resized" /> <img src="20170117_172532_resized" />
My Build Vidoes
CLynn85
CLynn85 HalfDork
1/17/17 9:24 p.m.
Ben - do you ever sleep??? Your projects seriously put my little chassis swap to shame!
Ben_Modified
Ben_Modified Reader
1/18/17 7:09 p.m.
Finished up the rear yoke
<img src="20170118_173012_resized" />
Trimmed it down around the perimeter
<img src="20170118_180101_resized" />
Pilot bushing in place
<img src="20170118_180431_resized" />
<img src="20170118_181356_resized" />
Project Videos
Ben_Modified
Ben_Modified Reader
1/20/17 6:11 p.m.
Progress on suspension. Made upper spring/shock mounts from 1/4" thick 6" wide flat bar. In the front, tubing comes up from the subframe to a brace that will bolt in place. It will be removable to extract the struts without separating ball joints and tie rods.
<img src="20170119_093043_resized" /> <img src="20170119_094333_resized" />
The brace will be clamped in place temporarily to determine proper ride height. Once determined, a flange nut will be welded into the top of the trimmed off tube. Will also weld a plate over the 1 1/2" hole thru which the bolt will go.
<img src="20170120_093328_resized" />
<img src="20170120_102302_resized" />
Heated and bent the ends of the tubes to match the strut angle
<img src="20170120_123356_resized" />
Started on the rear supports also. Mostly done, just need a couple of gussets.
<img src="20170120_171918_resized" />
The supports are out from under the car. The front is on its wheels and the rear in on a floor jack waiting for the gussets.
<img src="20170120_124742_resized" />
Project Videos
Indy-Guy
Indy-Guy Dork
1/20/17 10:08 p.m.
Ben, I'm in Awe of everything you build/post. Truly creative. Is this what you do for a living?
Ben_Modified
Ben_Modified Reader
1/21/17 6:22 p.m.
Indy-Guy wrote: Ben, I'm in Awe of everything you build/post. Truly creative. Is this what you do for a living?
Thanks! no, not for a living, just decades of learning things the hard way.
ssswitch
ssswitch Dork
1/22/17 11:14 a.m.
I feel like I need to work much harder on my relatively easy projects now. This has really come together.
1 2 3 4 5 ... 9
z6JYfGoh8wrGdBphdGzebmepP9BeASYbataWBjqgbh0881unbnnuYvktaQIh85LT
