BenModified.....will the instrument 'nacelle' be repositioned eventually....say within the next 8 hrs . I've been fascinated by ProjBnky, but this , your latest is way wack. Do you have any idea how this is gonna preform??? asphalt supermodified looking out the driver's window (at full lock) when going to the post office???....perhaps
Love it!!!
759NRNG wrote: BenModified.....will the instrument 'nacelle' be repositioned eventually....say within the next 8 hrs. I've been fascinated by ProjBnky, but this , your latest is way wack. Do you have any idea how this is gonna preform??? asphalt supermodified looking out the driver's window (at full lock) when going to the post office???....perhaps
Love it!!!
I like the post office idea! I will be using the instrument cluster from the bike and it will mount very easily to the dash. Glad you like the build!
Today, I finished up the shifter handle
And made up some bracing and brackets to install all of the Miata e-brake parts.
obviously the rear fender vents will be used to their fullest....cooling/air inlet ala '400hpvwsingcab'?
Aw hell go PHAT with a dodge diesel ram 5 inch mongo tail pipe.....can you say BLAAAAAATTTTTTT!?!?!?!!! BWaHahahahaaaaaa!!!!
I want to own everything you build! I love your style and your creativity. I have watched many of your builds over the years and subscribe to your youtube channel. I'm currently learning to weld and I look forward to starting my own crazy projects as well. keep up the great work on this! I love it.
B13Birk wrote: I want to own everything you build! I love your style and your creativity. I have watched many of your builds over the years and subscribe to your youtube channel. I'm currently learning to weld and I look forward to starting my own crazy projects as well. keep up the great work on this! I love it.
Thanks so much, I appreciate it!
759NRNG wrote: What's the estimated final weight again?
Shooting for 1200 lbs. I will weigh it at the recycle center when it is done!
759NRNG wrote: Is the harness nerve center mostly Yamaha?
All of the wiring is Yamaha. I will add a small separate harness for the twin headlights (with an on/off switch) and the wipers
759NRNG wrote: Talk to me about the electric reverse....seems as though you've done this before![]()
I have an electric reverse on my V8 Daihatsu HiJet. It is direct drive (clutch only). The reverse uses an extra flexplate and starter from a late model Taurus. Plentiful and cheap.
<img src="" />
<img src="
<img src="
If I can find a small diameter flexplate, I will go this route on the micro car, if not, I will use a belt driven starter/generator from a gas golf cart
759NRNG wrote: Ben_M is there a build thread for the V8 Daihatsu HiJet ?
Only partial, I started posting things a little late in the build GRM Thread is here
The build is pretty well covered on my youtube channel My YouTube Channel
I am going to use the original R1 motorcycle gas tank and mount it in the truck of the Autobianchi. I made the rear mount today along with more roll cage to body connections...complete with lightening holes.
Also used some exhaust tubing to start fabricating the floor. The tubing surround the rear section of the upper control arm. It is slotted to allow movement. The caps are for access to the control arm nut.
These are just plumbing caps which I have machined down to fit.
