1 ... 51 52 53 54 55 ... 63
SkinnyG (Forum Supporter)
SkinnyG (Forum Supporter) PowerDork
7/21/23 5:01 p.m.
Rad and fan installed and wired:
7/21/23 6:32 p.m.
In reply to SkinnyG (Forum Supporter) :
Trick of the lens, or is rad inlet at top center pretty much gonna crash the hose into the intake?
David_H
David_H New Reader
7/21/23 8:26 p.m.
Looking so good, can't wait till you be driving this bad mother jammer
7/22/23 12:31 a.m.
It will mostly clear.
I'm going to use hose couplers, and work my tube-fitting magic to make it clear.
Wideband is threaded in and wires into the cab.  Boost gauge is plumbed and hose run into the cab.  Harness is tidied and wrapped.
7/22/23 12:41 a.m.
I can't wait for first start!
7/22/23 11:14 a.m.
7/23/23 1:01 a.m.
Trial fit to feel good.
eastpark
eastpark HalfDork
7/23/23 8:05 a.m.
Wow, you really nailed the size - you can see everything quite well. I don't recall seeing the instrument cluster before. Is this custom?
eplas92
eplas92 GRM+ Memberand New Reader
7/23/23 8:25 a.m.
Long time lurker, love your truck and the color. Quick question though, what did you do for the intercooler? Sorry if i missed it. I have a 55.2 I finished up recently and can't seem to fit one up front at all. Just blew my headgaskets too because of the tiny radiator I had to run. Not much room in the bay of trucks of this vintage
7/23/23 11:18 a.m.
Eastpark: I was trial fitting the cluster and the wheel. It's a Classic Instruments cluster.  By the time I found ways to restore the original cluster, add the gauges I wanted, convert to electric speedo, it was easier to just order this.  I like the more "original" look of the Classic Instruments vs the Dakota Digital.
eplas92: The intercooler is a VS Racing 31x12x3, it came in the "Denmah" kit, I didn't really plan the size, figured I'd make it fit. I cut and boxed a lot of the rad support to fit it, but it does fit without cutting the grill.  The transmission oil cooler is mounted behind it (that's what the 1/4" bar is for), and I spaced the rad back 1" to fit the A/C condenser.
7/24/23 1:42 a.m.
Finally decided on where the battery is going to go.  For that, we need a mount!
First, in Fusion360:
7/24/23 8:47 p.m.
This will be mounted to the frame rail.  My intention with it is simply unbolt the whole bracket, drop it, and remove the battery.
Now cut it out of steel:
7/26/23 12:40 a.m.
I am confident enough that I have the in-cab wiring done, that I wrapped the wiring.
A while back I bought one of these trinkets - freaking awesome for troubleshooting, but ALSO for initial testing of circuits:
My truck came with a later 2-speed wiper/washer switch in the glovebox.  I still have the 1-speed motor, but chucked the single-speed knob in the lathe and drilled a 3/16" hole through the center, and I machined a wee 3/16" "button" with a 1/4" shoulder, back drilled to fit the switch pin.  Now I have a washer button!
The wipers do work - do they always operate a little "disconnected" from each other?  I mean, they do their thing, I was just hoping for more symmetry.
I installed pin-switches for the courtesy lights (and alarm).  That was tricky fishing the wire out through the hole.  Works, anyway.
Also added a toggle switch for the air ride compressors.  I mounted the switch inside the "ashtray" which I altered to house the air ride pressure gauges.
Ran alternator power and fuse panel power lines.  Also bought a wack of 1ga wire to go to the battery, now that I've decided where to mount it.
Now I need it back in the air to run the wires underneath.
So much work; so much to do.
7/26/23 1:29 p.m.
i have learned so much from reading this thread and watching your videos.
7/27/23 10:44 p.m.
I meant to powder coat this, but then there was this extra epoxy primer in the gun....
7/29/23 1:00 a.m.
The truck came with a later windshield washer equipped wiper switch in the glove box.  Good luck finding the 60-63 knob with a button.  So I made one out of the existing knob:
759NRNG
759NRNG PowerDork
7/29/23 7:59 a.m.
sent you a pm yesterday regarding the circuit tester
7/29/23 4:06 p.m.
Ah.  Yes, yes you did.  I didn't connect your signed name to your user name.
I picked it up off Amazon ( << link), probably the the cheapest one I could find.  I liked it so much I bought another one for work.
It can source voltage, it can sink voltage, and it can measure voltage. Also has a light which can be handy.  I find it handy for testing individual circuits before hooking up full battery to everything and letting all the smoke out somewhere.
7/29/23 10:38 p.m.
Taillights are wired, as is a trailer light plug.
Battery mount is set in place near the back of the frame under the bed.  Positive cable is done.  Need more #2 wire for a decent ground.
Air ride compressors are now hooked up, run through a relay and a pressure switch.  Looks like the pressure switch is 200PSI.  That should be fun.
Stereo amp wiring is run up to the cab.
8/1/23 10:48 p.m.
Air lines, and stereo amp wire plumbed into cab.  Need more DOT hose to plumb the air ride gauges.
8/3/23 12:43 a.m.
Air ride works.  Two Viair 400's drain the battery fast.  One air leak that I'll need to fix.
I ran -8 from the tank through a bulkhead fitting into the cab, into a log that splits into four 1/4" lines to manual valves, T'd to a gauge and run to each bag.  It actually lifts quite satisfactorily.  At 200psi in the tank.
Doubleoh9
Doubleoh9 New Reader
8/3/23 10:43 a.m.
Just finished re-reading through this build, truck looks fantastic and your work is stellar!
8/4/23 2:01 a.m.
Manual paddle valves for reliability and simplicity.  Modified an -8AN bulkhead fitting to be a bit shallower.  The gray is etching primer over the drilled holes. Air is distributed from a 4-into-1 manifold.
8/5/23 12:40 p.m.
8/7/23 9:16 p.m.
Wiring is done.
Stereo is in and working
Cooling system holds water.
I've been over-thinking the engine oil cooler for three years.  Today I bent up two little mounting brackets, and once they come out of the powder coating, the cooler will be ready to hang.
I -think- all I need to do is throw in a new battery, pressure test the fuel system, pressurize the oil system, and it should run.
I'm scared spitless.
zhaRoqYC6QZOTqaxNraMFPKU7q01uLu32CBgHOi10G0yq6B5dQ4YvEHqciOkidiz
