When we tore down our $400 LS1, we discovered some positive things and some negative things. We also discovered a horrible thing: The stock 853-code heads, which are regarded as some of the worst flowing to ever top an LS-based engine. We didn't quite know what our engine's destiny would be, but we knew there was no sense in …
5.3L heads can have LS1-sized valves installed in them, and have a slightly smaller combustion chamber that will give a compression boost.
Good to see this one's still moving forward albeit slowly. What years and models did the 799 heads appear in?
5.3 heads have been a well kept secret for a while. How do you think you get 400hp from a 5.3 with just a cam change and a carb? It is all about the stock heads on those being so good.
