MadScientistMatt
MadScientistMatt UltraDork
3/3/14 2:05 p.m.
Ran into a snag dyno tuning the 4.8 swapped C10. I used the TH350 and, for dyno tuning, have left the kickdown disconnected. (Vacuum modulator is plumbed up, though.) While trying to hold it in second gear past about 70% load, it will run for a couple minutes, then start slipping horribly and won't stop until it's sat for a while. Shifting it into Drive does not get it to engage at this point - it acts like it's in neutral when this happens.
Does this sound like the transmission is shot? Just plain needs a cooler? Or is trying to run close to full power through a TH350 for a long period of time asking too much of it?
Kenny_McCormic
Kenny_McCormic UberDork
3/3/14 2:10 p.m.
Doesn't the kickdown effect line pressure, and thus, how hard the clutches will grab?
Ranger50
Ranger50 PowerDork
3/3/14 2:15 p.m.
How's the governor?
It very well could be on it's last legs..... Easily rebuilt in a sandstorm with noting but simple hand tools. I'm betting on the apply piston seal is worn out causing the slip.
Streetwiseguy UberDork
3/3/14 5:32 p.m.
TH350 doesn't care about the cable- I think. The 700's use the cable for throttle pressure because they have no vacuum modulator, so it needs the cable working correctly.
I'd consider hooking a wire up to the lever so I could reproduce full throttle just to see if it makes a difference.
MadScientistMatt
3/4/14 7:45 a.m.
Thanks so far - any sort of testing I can do without opening the pan, like maybe testing the fluid temperature?
K6sRHzEWAaE1WslNYB8QfUuRzENtEYAo0VsBKDh84ZxGZ1Hx5TTItgZMkQGc3Myf
