There's a company based in Phoenix, Arizona, that makes a little magic box called Auto-Blip. Basically what it does is sense when you are downshifting and gives your car the necessary throttle blip automatically, without throttle pedal input by the driver. Purists may scoff, but this is could be a good way to trim lap times. To find out exactly …
We do this as an option in our reflashed Miata ECUs. Takes a lap to get used to it, but it works well. I don't think it has any real effect on lap times if you can already heel-toe, but it does force you to use a consistent rhythm when shifting.
The flat shift is pretty fun too.
Didn't the 370Z come with an automatic heel-toe system from the factory?
My Evo X MR does it, but its a DCT, not a manual.
^^^ yeah, the 370z had a similar system. It did a pretty good job of blipping the throttle when you wanted it to. I found it kind of annoying since I regularly heal and toe without really thinking about it. Fortunately you can cancel it and turn the option off--- so no harm. Use it if you want, don't if you prefer to dance on your own.
I prefer to do the old heel-toe dance by myself. I could see this being useful if you cant move your foot that way though.
tomtomgt356 wrote: I was expecting this to be a discussion on heel-toeing an automatic. I am slightly disappointed.![]()
It's totally do-able if the trans isn't too smart (the smart ones tend to get confused by a throttle blip combined with a manual downshift). But why heel and toe when you've got 2 pedals and 2 feet?
rslifkin wrote: But why heel and toe when you've got 2 pedals and 2 feet?![]()
Because you need your left foot free to control the emergency brake when you try to power slide while heel-toe downshifting in your parent's mini van with your girlfriend in the front seat (not that that ever happened nor would I ever recommend it).
tomtomgt356 wrote: emergency brake... power slide... mini van
Yeah, that's not a power slide. Power slide is RWD only, as it involves kicking the tail out under power. If you're using the e-brake, it's a drift, but specifically not a power slide.
In reply to rslifkin:
My adult self knows that. My 16 year old self, not so much. Note the operative word "try".
In reply to tomtomgt356:
You were 16, in a mini van with your girlfriend, and you were in the front seat?
You lost me at "drive by wire." My concept of DBW is that the throttle cable is the wire. I don't need no stinking throttle servo motor; that's why God gave me a right foot.
P.S. You should be able to built this with an Arduino for about $70, either for direct application to a DBW car, or as an add-on to MicroSquirt with a stepper motor for the throttle linkage in a DBC car. That would be worth some braggin' rights.
JBasham wrote: You lost me at "drive by wire." My concept of DBW is that the throttle cable is the wire. I don't need no stinking throttle servo motor; that's why God gave me a right foot.
Then you must not be driving anything built in the 21st century.
jstein77 wrote:JBasham wrote: You lost me at "drive by wire." My concept of DBW is that the throttle cable is the wire. I don't need no stinking throttle servo motor; that's why God gave me a right foot.Then you must not be driving anything built in the 21st century.
Bingo, if you mean "tracking" instead of the broader "driving."
Anyone who thinks that a throttle cable is superior to DBW doesn't know much about engine management. It's like the jump from carbs to EFI.
And yes, there are still people who think that sloshy toilet bowls of fuel are better than EFI as well, but they're learning...
rslifkin wrote:tomtomgt356 wrote: emergency brake... power slide... mini vanYeah, that's not a power slide. Power slide is RWD only, as it involves kicking the tail out under *power*. If you're using the e-brake, it's a drift, but specifically not a power slide.
Once upon a time, perhaps before you were even a twinkling in your mother's eye, there once existed - hold your breath - REAR WHEEL DRIVE MINIVANS!
jfryjfry wrote:rslifkin wrote:Once upon a time, perhaps before you were even a twinkling in your mother's eye, there once existed - hold your breath - REAR WHEEL DRIVE MINIVANS!tomtomgt356 wrote: emergency brake... power slide... mini vanYeah, that's not a power slide. Power slide is RWD only, as it involves kicking the tail out under *power*. If you're using the e-brake, it's a drift, but specifically not a power slide.
jfryjfry wrote: Once upon a time, perhaps before you were even a twinkling in your mother's eye, there once existed - hold your breath - REAR WHEEL DRIVE MINIVANS!
Very true. But the mention of e-brake being used combined with FWD minivans being more common led me to believe that the van in question was probably not a Previa or other RWD minivan.
rslifkin wrote:tomtomgt356 wrote: I was expecting this to be a discussion on heel-toeing an automatic. I am slightly disappointed.It's totally do-able if the trans isn't too smart (the smart ones tend to get confused by a throttle blip combined with a manual downshift). But why heel and toe when you've got 2 pedals and 2 feet?![]()
I will say it is situationally dependent. Some manual cars have truly lousy pedal placement for heel-and-toe, and it is not always the easiest thing to correct. Also, some folks have, for what ever medical reason, ankles that will no longer (or never did) rotate well enough to manage a heel-and-toe.
Keith Tanner wrote: Anyone who thinks that a throttle cable is superior to DBW doesn't know much about engine management. It's like the jump from carbs to EFI. And yes, there are still people who think that sloshy toilet bowls of fuel are better than EFI as well, but they're learning...
Some people aren't ready for the truth.
No doubt, which is why I didn't say superior, Keith. For me, Ford EEC-IV/EDIS ignition V8s with a throttle cable and aluminum heads are just the cheap and easy button for a fast track car. They are not optimal automotive engineering technology. My BMW S65 V8 is a much better example of the latter, but Jesus the extra 70hp is freaking expensive.
Not that it will keep me from turning one of the Ford 302s into a DBW some day, now that the Internet of Things has gotten so damn cheap and DIY-able.
Fair enough, if the goal is cheap and easy the cable still rules. Engine swaps are easier when you don't have to worry about matching the pots on the throttle pedal sensor, and CAN is a whole new ball game.
The OEMs are taking big jumps in complexity, the gulf between what they're doing and what the aftermarket can do it opening up rapidly. Most of their goals are efficiency and emissions, so we can sidestep that.
I apologize for the tone of my last post, tough morning and it bled over.
IDK about the 370Z but I was reading the BMWs that have autoblip turn off when you turn off traction control. I always thought of it as a track aid like what the OP says so that kind of defeats the purpose. Is the 370Z's system like that?
In reply to kanaric:
Yep, this is true. Had a rental with that feature when I was over in Germany. Since I always heel-toe anyway, I actually didn't know it had the feature until the 3rd or 4th day of driving the car when it suddenly revved itself and at a strange intersection as I went from 3rd to to second. After that, I let it do its thing for awhile, and it's pretty darn good, but I enjoy the challenge of doing it myself. Fortunately, if I was doing it myself, I really couldn't tell a difference with it on vs off, so it's really unobtrusive. I was pretty impressed with how it was programmed.
